Melon Head's State of the "DUMB" Open Baffle Design
First off: Attention all intelligent people, there is nothing to learn here.
This design has no right to belong in this dimension, but I was determined to make it happen.
It is no secret that I am not the brightest spark going around, so this design is dedicated to all the "dumb" people.
I intentionally designed this with out any regard what so ever to accepted design principles, just to see what can be produced by following the "Suck It And See It" philosophy of speaker design
STAY TUNED
So far I have decided to go with dimensions of 45cm wide x 120cm tall. That seemed as good a number as any. I could have gone with 42cm but I will incorporate that number in the design later on somehow. I don't want an anti-climax so it is not good incorporating that number too early in the design stage
All will be revealed soon. I will be incorporating the Seas FR driver in this design. I will be playing around with every dumb idea possible and taking measurements along the way.
It is hard for a dumb person to understand the ways of smart people, and yea I am a man of lttle faith (and 1.5 brain cells). So this will be dumbness meets myth busters. :rofl:
Official Court Jester
Joined 2003
no porn no fun
just words
Seas Break In
One Seas FA22RCZ was broken in using 10Vpk Sine Wave swept from 30Hz to 45Hz.
Looks like things have stabilised. I will give it another 24hrs to be sure.
Once I have built up the baffle I will see if I can hear the difference between the broken-in driver and a new one out of the box.
Hopefully have all the wood cut by tomorrow.
Then repeat the break in process for the new one.
Just another Moderator
Joined 2003
What are you using to do the T/S measurements? I've always used Speaker Workshop, but recently measured some new 4" drivers and the FS (and other params) were way off. I ended up trying with REW and got completely different results that were very close to manufactures specs.
I'll have to measure the impedance of my tweeters again. I'd always been a bit disappointed that their fs seemed to be about 200Hz higher than it should have been. I suspect that SW gives inaccurate results for speakers with very light diaphragms.
Tony.
I have my own program at work that was done in Matlab, but I am using Dayton DATS at home, so people can easily compare results if they have the same gear.
Edit: The TS Parameters change significantly with signal strength, and the drivers need to be broken in.
I need to check what the output is on the Dayton gear
Frequency plot of Seas on 1m baffle. I will turn it around and see what the difference is.
EDIT: The baffle is 1 m wide x 80 cm tall with 20 cm wings.
The centre of the speaker is 17cm above ground height
Joined 2006
Yeah no worries. I am a fan of FAST
The show is not over till the fat lady sings.
You know how easily tempted by that remark - but we have already done damage to Chris and out of consideration of not having to send him off to mental vision re-hab I'm gonna pass on this one. :D:D:D
Do not make the mistake of my being kind as a sign of smartness tho because I am still a big Dummy! :rolleyes:
For example - every time someone mentions "one meter" this or "two meters that" I keep looking around to see how many meters I have around the shop. I have a gas meter outside - a digital multimeter on the bench - let's see - what else iz around here.
