Put marble feet and wooden knobs. " THEN, after you have actually heard the improvements, decide whether you want to go on or not."
I like your hypnotic formula. It is classical, contains nice presupposition about "after you have actually heard the improvements".
Nothing "hypnotic" about it.
I have come across very few components, mostly Technics integrated amps, which were upgraded, and did show some improvement, but the gain was way less than the investment. All to the one used Technics' hybrid output stages.
Which led me to believe that this simply cannot be improved on meaningfully without changing those hybrids, and since I hate hybrids, I never tried and never will.
I stand by what I said - improved power supplies will always yield an improvement, but that improvement may be out of proportion with the investment. Low bang gain per buck. In other words, not worth it.
Ditto for some Kenwoods from the second half of the 70ies, however, more could be done because the entire power amp circuit was a hybrid, consisting of a discrete voltage gain amp and an integrated output stage. Sort of like LM 381 in reverse, it was the voltage gain stage needing a discrete output stage.
Classical induction with presupposition.
Change one word and it is no more hypnotic:
" THEN, if you have actually heard the improvements, decide whether you want to go on or not."
I remember London in 1970. They used to advertise jobs in the London Underground that started with 13 pounds/wk, as I recall.(I was 28)
The American dollar went a long way, in those days, in London. By 1976, my techs were paid 1 pound/hr by Ira Gale. Kind of low, I think, because the rich guys got a lot more for their efforts.(kind of like, America today'-) Big class difference in wage, at that time.
Have you ever measured the difference before and after you changed to wooden knobs? You just might be surprised by how large a difference that can make and why it does!
Now marbles for feet I don't know about, but rubber pads can make a difference on some gear under certain conditions.
Just remember absolute statements never are right, absolutely!
You damn well know that's what I meant, I've spoken out against the placebo effect here often enough.
OK, fine - IF you hear improvements, ....
No. Two different implementations, which did not mixed their names.
Infinitive baffle, is the older (and more generic).
Acoustic suspension, around middle 1950 by Edgar Villhcur, implemented and marketed by Henry Kloss
Yes. The boxed air is to act like a spring to the cone (and cone is to be supported with a compliant suspension)
George
In current syntax , IB is not a sealed box. IB provides no loading other than the baffle. A lot of things were called different things. Madison Av at it's best. ( for the world audience, this is where the big American advertising firms in New Your are centered)
I find acoustic suspension first described in Edgar's paper to AES in 1957 while he was at AR. Curious he suggests a Q of about 1 to be most flat.
The sealed box is still a ported box, but the port is closed simplifying the equations.
Out of my own interest I cranked up my Google Fu and found a few interesting things. These go back to Tektronix and are state variable rather than Wien bridge, but the interesting part of this one is the "leveller" or amplitude detection circuitry. It sums several phases through diodes to give a smooth-looking peak envelope and effectively "sampling" the waveform several times per cycle:
Low distortion oscillator
4,560,958 "State variable oscillator having improved rejection of leveler-induced distortion" This takes the signal at the variable gain stage and combines it with an inverted output signal to partially cancel the distortion:
Patent US4560958 - State variable oscillator having improved rejection of leveler-induced ... - Google Patents
With "suitable modifications" these could conceivably be applied to Wien bridge oscillators.
An interview with Hofer: "He has received 13 patents,..."
How new products challenge audio test - 2010-06-01 04:00:00 | Test & Measurement World
How new products challenge audio test (continued) - 2010-06-01 04:00:00 | Test & Measurement World
I have an Optimation AC calibrator from about 1972 (pretty much predates IC's) that uses a state variable oscillator from 10Hz to 1 MHz and has .005% THD and flatness to .005% or so to 100 KHz. It uses a sample and hold that catches the peak of the sinewave (triggered by the cosine wave) and settles very quickly. I have not seen this trick outside of the precision calibrator world. It also has more Vishay S102 resistors in one place that anything I have ever encountered. It has a six digit attenuator all built from S102 resistors. When I checked it a few years ago it still met spec, after 40 years.
Demian, do you recall what the purchase price was? Those vishays alone would have pushed it up. How nice that it is still in spec.
One of the other SV approaches that I've seen uses analog squaring circuits on the quadrature outputs and sums the resulting signals to get an ideally ripple-free voltage proportional to amplitude, which then requires far less filtering in the stabilization loop and consequently less control voltage feedthrough and distortion. Another of those great ideas that occur to more than one person (I later found it in a Burr-Brown book after thinking of it myself). Of course good low-noise analog multipliers are tough to make.
Brad
I have the catalog at home. I'll check the price. I think it was something like $5K in the early '70s. I bought a house in San Jose in the early '70s for $12K which should put it all in perspective. The inflation calculator translates that to $25K but it suggests that it would be around $950 is still in production. The current equivalent Fluke (not really the same since it does more and is much more automated) is $36K.
The value of good design it that it will be in spec for a very long time. That comes from serious design work and lots of careful engineering. Today's state of the art for this class of product has not moved much. The accuracies are only a little better. Ease of use and programmability is much better, important when dealing with a complex calibration process.
Sounds interesting, but how precise are sine to cosine waves in phase? What insures this precision?
However, when measurements are done on exponential scale so strict amplitude stabilization is not needed at all. When measuring on linear scale sine wave purity is not significant, so an ordinary functional generator is the way to go.
2 different inexpensive generators are the way that I prefer to go.
In 1070'th I used a huge HP signal generator, vacuum tube based. It had couple of RF oscillators, multiplier, and CRT with 1 KHz camertone fork - based oscillator to set frequency by Lissajous figures. Quite interesting toy, huh?
Actually sine wave purity is very important since it causes significant errors in AC sine to DC comparisons. It also causes errors in different AC to DC conversion methods. Things that seem unimportant become really important at .01% accuracy.
Actually to me it is important when measuring spectrum or frequency response on log scale. But when I observe on oscilloscope what happens in linear scale I don't care about signal purity so much. It is like to have good GPS in a car, good radio/mp3/whatever - player, and good CCTV, VS all in one toy that can do everything a little bit deciding for me if I want to search for nearby gas station, or I have to stop a first right on the freeway to do so.
What's the point in meeting contradictory requirements in the same tool when combining them results in worse and more expensive end result?
The matching of each integrator can be tweaked pretty effectively. Once thus matched, quadrature is assured. The input resistors can be adjusted to compensate for the difference in capacitor values. If the amplifiers are sufficiently high frequency the performance at audio frequencies can be very good. One of the advantages of the topology is the absence of common-mode swing of the integrator amplifiers. With one additional amplifier as an inverter it's possible to make all the amplifiers have a very small common-mode swing.
But usually one wants tunable frequency, so probably the best way is via code-programmable step attentuators (i.e., multiplying D-A converters) in place of the fixed integrator resistors. Then the requisite codes can be saved to keep things in quadrature.
Actually as long as the resistors match to close tolerances and the caps match the amplitude stays constant and the phase is constant. The phase is constant even if the amplitude shifts and the sample pulse is triggered by the zero crossing. Its a very elegant solution.
A scope is rarely better than 3% if analog. Digital scopes can be better but precision long scale meters are .005% or better for AC and the small distortions are important for the calibration process. I'm looking for a reference but most are behind paywalls or buried in long articles. If I can find one I'll post it.
You can learn a lot about analog accuracy from repairing these types of instruments or studying the circuitry. The details of construction and design will show a lot of things learned from experience and analysis.
Placebo effect can be caused and directed by hypnotic inductions. You know that.
"And now while you sitting here comfortably relaxing with each slow calm breath listening to this music please tell me does it relax you or not"
True, no disputing that.
However, I still stand by what I said - if you significantly upgrade your power supply, no matter what you have except perhaps the best of the best, you WILL be able to hear a positive difference, although it may have a bigger or smaller impact overall.
I say this from persopnal experience, although I must add that the total number of devices I have worked over is not very large, say around 20 over the last 20 years. I don't do it for a living, usually I do it for friends only, hence the small(ish) number.
The word "significantly" is also open to discussion. As an example, I'd say that if I throw out 15,000 uF caps and put in 22,000 uF caps, which is around 50% more, that would be a significant upgrade. If in the process I also take out a say 300 VA transformer and put in a 500 VA transformer, that starts to look more like a rebuild than an upgrade, but I still call it an upgrade. To me, it starts to be a rebuild when I do all that, and then start swapping transistors, typically exchanging lower for higher power ones.
My point is, when someone tells me he has upgraded whatever, I cautiously ask exactly what has he done, just to be sure, to know what we're actually talking about.
If you look at a spectrum analyzer at the ripple of a PSU it argues well for any improvements that can be made . Harmonics are strong way past 1 kHz . What astonishes me is that transistor people almost never fit chokes ( not even me ) . I haven't calculated it yet and perhaps the gains are not large . The thing to note is not only lower but nicer harmonics . I would say 2 x 10 000 uF with choke between might out gun 47 000 uF and be no more expensive , one can even do the valve trick and have a lower ripple rating on the second cap if you please . I assume 4 caps and 2 chokes . When I get a moment I will try it . As for chokes . I would try off the shelf toroid's ( a mains transformer ) . Funny thing I find is valve people obviously eat caviar for breakfast as the prices are outrageous . A choke can be made with a hand drill . If you have some M6 metal and ordinary metal you can play with the inductance . My rule of thumb is make the wire double what it would be in free air as a start point . I doubt if greater than 1 mm for most users ( 14 A free air ) . You can pot the chokes as it helps heat a bit . I found that be accident . I use Robnor 1113 g polyurethane from Farnell . Cheap and good . You will have to make you own safety checks . If the potting doesn't melt is isn't a problem usually ( i.e . hot ) .
Julian Vereker said to me his amps got better and better whilst he had done exactly nothing . He went on to say unrequested by him the capacitors just got better and better . His observation being the computer industry perhaps demanded it .
I got the PSU bug from Naim . Basally nothing except the transformer was different in most of their designs . Big sonic difference . Night and day I would say . That's where teaching goes out of the window . I have measured everything regarding that . Mostly what people say can be disproved in seconds when measuring . There is no simple explanation . I suspect the iron core in a class B amp is an energy store and that all there is to say . Better regulation and noise simple do not come into it . Noise is dreadful as with all transformers almost regardless . If not how would we use them for valve output stages ( you can use mains transformers , they work better than you would think ) ?
My friend got me to design a new PSU for his phono stage . The box had already been designed . I could have 80VA max with 1 watt load . I felt a bit cheated ! The design has 3 mm to spare . I am using the small terminal IEC inlet as it gets me 2 mm .
DVV , when I said we were poor I meant the nation . I have worked hard all my life ( from 13 on the farm , now 56 ) . I always had money .
My Wavebourn , any good links on hybrid cascodes ? ECC82 bottom ECC81 top ( all ECC81 ) ? Valve Wizard want's me to play guitar . I was wanting something above the pseudo pentode knee .
Any better than 5534 ? http://www.ti.com/lit/ds/symlink/opa627.pdf
Not these days, but how many years does the average audio DIYer curriculum span ?
In the early to late 1980s, CLC was rather popular in some areas.
Example : http://www.albs.de/Spec/Netzteile1_Info.pdf
What do you mean?
I don't remember any famous musicians that used hybrid cascodes. What kind of special effect would you expect from them?
A first guitarists found that overdriving amps made from datasheet examples they were getting sounds they liked. Then what they liked was shaped in specific guitar amp topologies. May be if datasheet examples contained cascodes they would go this way, I don't know. I played a lot with guitar effects, but all effect that guitarists liked were similar to what they already heard on records of famous musicians.
- Member Areas
- The Lounge
- Sound Quality Vs. Measurements
