Sorry but decrease means increase the output voltage!
Are you sure?
PSUDII is your friend here...........download it and play with the values......
Please can put the link?PSUDII is your friend here...........download it and play with the values......
Are you sure?
yup
what's difference ?
0R2x2A = 0V4
I need to reduce from 27vdc to 25vdcyup
what's difference ?
0R2x2A = 0V4
so i need to use 1Rx2A=2V W=VxI 2Vx2A=4W but for to be quiet for charging time of capacitors after R i prefer to use a 10w.
Are you agree?
no
go to 27V
you'll kill dynamics that way
Ok!Now it is clear! it Is for dynamic problems!
Ok! Thanks ! Please can you schow me your CRC value of your PSU?
never more than 0R1
Ok I will listen to your advice!
short C1 you don't need it
pull out R10 , you don't need it
for C3 use decent cap
for C2 use Silmic , bypass it with 100nF MKC (polycarbonat)
Upgrade just done!!!
The sound now is much more detailed and more focused!
Upgrade very recommended!!!!
My suspicions on C1(its position end its typology) were founded !
Meny thanks ZEN !!!
Hi!Zen
This Your suggestion has already been done!And i thank you!
Now i need to do the second fase of modding
Since i should buy the capacitors ,i would like to find an alternative to replace the electrolytic capacitor C2 that is not certainly the best choice for the passage of the signal(even in a feedback),might suggest me a better alternative?
I read that someone has used in aleph j some K73-16 (from 40 to 60 uF) I would be happy to know your opinion on this theme.
Thanks in advance!
So.... if i would use one of these for c2 (i have these in my home)Silmic is good for Papa
it's good for me too , especially bypassed with MKC
just say that most expensive Blackgate isn't better in that position
been there , done that
ELNA CE-BP 220uF 16V BI POLAR CAPACITOR *NEW*
Number ebay item: 260815852652
Or these
Nichicon BP 220uF 25V MUSE ES BI-POLARIZED for Audio Capacitor Caps
Number ebay item: 140618205767
With 10nF mkc in parallel,do you think the result would be less than Elna Silmic 2 capacitors ?
If not what kind would prefer between of two mentioned above?
Thanks.
I've removed C1 and R10 and bypassed C2 with a .12uf MKP and it's an improvement. I'm assuming removing C1 is probably the biggest reason...my guess anyway. Also reduced R14/R16 to 866R. Next up is to replace the generic bridge rectifiers with FREDs....any maybe lower the source R's.
Why have you reduced R14/R16 to 866R, have you problem with the bias?
See this thread starting at post 806:
http://www.diyaudio.com/forums/pass-labs/2001-mini-17.html
Ok!Thanks for infos!
- Aleph 30 the best choice of C1 C2 C3 on brian gt PCB
