Aleph J Schematic
Official Court Jester
Joined 2003
gimme voltages across :
Z1,R8,R7,R18,R17,C-E of Q4
are you sure that your 2SJ109 are genuine ?
I have found on ebay at alweit 2 pairs of J74BL at these matching specs : 2 very well matched pairs: I declare +/-2% to be on a safe side but really I select no more than +/- 1% (Vgs = 10V) - really, I allow maximum difference between pair is 0.03 mA(I know the matching between channels isn't necesary)
and spencer has this specs : As in the past, the match from part to part is within 0.2mA assurance but you will get normally within 0.1mA tolerance. The Idss accuracy is about +/-0.1mA due variation of equipment and temperature during test. Special requirements may or may not be fullfilled and it is a case by case discussion.
Guess the first ones are the best, right?
