i've read it here a while back that when possible the interconnect cable should be the longest to cut down on other connectors' length- is this true?
meaning the best result is to be had by having the longest cable from the line stage to the amp with the shortest wires to the speakers, provided that the line stage is active.
could i get an explanation behind this?
and what about the signal length from the source to the line stage? does the same rule still apply?
Unless your line stage has low output impedance it is the interconnects which need to be short. ICs and speaker cables have vaguely similar (to within an order of magnitude) capacitance, yet the difference in source impedance can be three or four orders of magnitude. That means that any effect of capacitance, such as dielectric non-linearity, is likely to be worse for an IC than a speaker cable. Now I am not saying that there is an effect, I don't know, but if there is then ICs should be short even if that means longer speaker cables.
You need to be aware that this is the opposite of the advice which most people will give you.
At 1W 8 ohms I can hear 25' of 16 ga zip cord sounds worse than 10' of AWG 10 extra flexible. AWG10 3SO cord is $4 a foot or more, so you can't afford a lot of that. Op amps line drivers are not so worried about series resistance, whereas the high currents on high resistance connections from an amp to a speaker mess up damping etc. The distortion I hear on zip cord is on top octave Steinway grand piano, so it is not just damping that is messed up, that is a bass response number.
I thought that the larger diameter cabling should ideally be used with the longer length run... it seems that this example is not following that rule...
could that be part of the reason the longer cable 'sounds worse'?
If you are European or Asian, 10 AWG is a lot fatter than 16 AWG zip cord. Much more copper.
Longer cable more resistance. The feedback circuit of the amp stops at the speaker terminal. The feedback circuit is what controls distortion. So what happens out there at the speaker is uncontrolled by the amplifier. Op amp line drivers run low currents, 10-30 ma, so the resistance of 100' of snake cable is not significant. The capacitance of the twisted pair is more of a factor, and the 60 hz pickup is way more of a problem at 100'. Power amps run currents of 5-22 amps, so V-I*R, the voltage of speaker wire can become a measurable quantity over 6'. Look at pro stage sound setups before radio mikes and mixers. The mixer was in the audience because that is where the sound must be balanced. Condenser mikes made that possible because they have a built in line driver. They ran snakes out to the mixer board from the condenser mikes and back to the power amps on stage. The power amps were always up there next to the speaker, because of the current causing voltage drop problem.
If the connection was balanced and the cable was shielded twisted pair then yeah, that'd be great.
Hang on!At 1W 8 ohms I can hear 25' of 16 ga zip cord sounds worse than 10' of AWG 10 extra flexible. AWG10 3SO cord is $4 a foot or more, so you can't afford a lot of that. Op amps line drivers are not so worried about series resistance, whereas the high currents on high resistance connections from an amp to a speaker mess up damping etc. The distortion I hear on zip cord is on top octave Steinway grand piano, so it is not just damping that is messed up, that is a bass response number.
Let me look at this, you are comparing two different cables, that are different length, different gauge and different construction or different dialectic structure or thickness?
So what is contributing to the sound difference?
One of these factors, or two, or all?
I go for low capacitance, and low inductance in both uses, as best I can. But that's just me, and I'm pretty new to all this....relatively, so just my novice view. For both I go for solid core copper, 20awg for speaker cable and 24awg for ICs.
Edit: Easier to show how I construct ICs, rather than explain it, see here http://diyaudioprojects.com/Power/diySilver/ not my page, just that it is the same way.
Yeah, the cables are different. I picked up the extra flexible 4SO10 cord out of the dumpster, knowing that fatter is better. I've used it for years, even on my ST70 tube amp that only puts out 2 amps into 8 ohms. Then I wanted to carry my speakers out the door on the 4th of July and blow 1812 overture all over the yard so I cut up some old yard light zip cord into two 25' pieces and tried them out. Then, later, inside, I did a listening test on the zip cord before putting the 10 ga cable back on. It sounds worse on my test record, top octave solo Steinway piano (Peter Nero, Young & Warm & Wonderful, Secret Love track). A sound engineer was just saying on another thread, that studios use piano tracks to test their setups. I have never had speakers that sounded anywhere close to even my Sohmer piano, until I bought the Peavey SP2-XT's. But they sound closer to real with the 8' 10 ga cable instead of the 25' of 16 ga seven strand zip cord. The amp that day was the CS800s Peavey, but the dynakit ST120 with djoffe bias mod and modern NTE60 output transistors sounds exactly the same in my opinion, at the 1W I use in the living room.Hang on!
Theory? I don't know. I have seen discussions of damping factor being related to cable impedance, which makes for tighter bass. Damping factor is not an element of top octave Steinway piano source material, that is more messed up by intermodulation distortion. So I don't know why it messes up the sound, but it does. The 4SO10 has rubber insulation and about 1 twist per foot. The 16 ga zip cord has PVC insulation and parallel runs. For calibration source, I have the real Steinway piano setting between the speakers. The bass of Mr Nero's 11' studio grand is better than the bass on my 40" console piano, but the treble sounds are pretty close to the same.
And I don't know anybody that hooks up speakers with anything thinner than 18 ga zip cord. Monster cable has gotten rich selling fat cable for speakers, but the 4SO10 extra flexible industrial cable for 440 VAC 3 phase mining equipment is excellent, in my opinion. If you can afford it.
Piano tracks are great for comparisons, I look for a close as possible to a natural tone and decay in any tweaking I do, drum decay is another thing I look to.
I'm making some speaker cables tomorrow, 1.5m long using solid core 20awg Neotech copper with a Teflon dielectric, one run for each of the terminals.The Neotech copper is long drawn so It's one continuous crystalline structure. I don't use more than about 20awg with a solid core as you end up attenuating the top end is It's as thick as 1mm, this is of course with a solid core, and you don't get this with a stranded wire.
As you might gather, I prefer a solid core over stranded, although I have used a stranded wire in the cables I have in my system ATM.
Monster cable is IMO awful stuff, I replaced a $400 monster HDMI cable in a friends system with a good $18 HDMI cable and it was slightly better sounding, and had a slightly more vivid picture than the Monster one.
Edit: I think with anything in our systems, a big part is synergy, what works in one system may not be suited in a different system. And then we have our personal preferences *thumbs up*
Prove it.
This is all subjective fantasy and opinions are like a holes...
Interconnects and speaker cables are inaudible unless your lengths are extreme, or your electronics are crap. If you think otherwise you need to prove it with some blind testing.
Any decent mic makes that possible because they are engineered correctly. (200 ohm impedances on ballanced lines)
Again, prove it.
You suggest that there is no difference in sound between cables and ICs?
I suggest you cant hear the difference between any properly engineered cables (which cost as little as $1 a foot) unless your electronics are crap.
This subject has been flogged to death more than once, in threads that are over a 1000 posts long. Do we need to do it again? Looks like it.
I have no need to prove anything to you, and definitely not to anyone that also heard & viewed the differences also.
You prove me wrong!
If you keep it to yourself, than you dont have to prove it. Im not the one making claims, what exactly am I to prove. Its like asking me to prove that you didnt see god.
- Design & Build
- Parts
- best arrangement to cut down cable lengths
