F5 power amplifier
While you are waiting, don't forget to order your F5 turbo-jet neck-tie :rolleyes:
-Mal
Joined 2006
Forgot to say;
Board is 350mm x 50mm.
Phoenix connectors for Input, Output and Power.
Minimum track width 1.2mm (1.6mm on output devices).
1.6mm board woth 2oz copper.
350MM probably makes it too big to fit into the common Conrad heatsinks a lot people use. A little smaller might be nice, only if this is something you plan on getting rid of.
