Ultra Simple Class D
Hi Diyers
Greetings. simple 200W amp works first time on simple parts only I don't have output inductor with this inductor amp is working Credit goes to Norazmi for helping me to make this amp possible
Warm Regards
Andrew Lebon
Reactions: 1 user
That looked a little TOO amazing until I saw the two screws at the top holding down what appear to be TO-220 semiconductors on a heat sink underneath the board. I see the three leads of each coming up through the board. With a single-sided board it's gotta be simple!
ULTRA SIMPLE CLASS D
Hi
greetings i will post pcb and component layout for this simple amp
components ic TLO74 OUTPUT transistors IRF 540 IRF 9540
2N5401 2N5551 BD139 BD140 SUPPLYtransformeri used is 20 0 20 AC tested till
33 0 33 AC transformer all i can say it comes on first time output transistors
are very cool on 4ohm load amazing bass and clarity pcb size is 8cm by 5cm
for anyone making their first d class amp this amp is a good starting point 200
watts
warm regards
andrew lebon
Nice little Class 'D'...............Glad it works as planned....Do you have any specs on it...performance parameters perhaps.
Just who is this other site & why are they so adamant toward not sharing information? The greatness of internet forums, regardless of the field of interest , is a free exchange of information..............an open book if you will. Commercial interests are few & far between as the likely-hood of profit is extremely thin within this industry.
______________________________________________________Rick..........
Class D pwm Amp
here is my diy of this amp
running at 50vdc idle offset 8.5mv inductor 47uh at 100 hz =28.27vac=206 watts 4 ohms load
