ok
just add m after 20 ...... and ignore the rest
(besides ...... every proper Greedy Boy is already thought to ignore tech part of my posts ... if not all parts )
I see. LM317L then okay? (TO-92 regulator)
Cap/Zener too.
Zeners are noisy, but in this application with such a little gain should not be a problem...
Franz
Zeners are noisy
Hence Cap.
Like I said, I've posted a schematic for a proven solution at the beginning of this thread.
Mike R,
I use the 15R lowthers...
Hello Mike,
I'll post some info for you when I get home, but you may want to peek at Post #23 for now.
o-k- with your CCS the hum was really absent...
I am still not happy with so much wattage in resistors......
so I am open to try another CCS solution, really!
Here is a plain one, though not that bad, in case you will need it. (Q3's drain is pointing ''north'' in the schematic, you may use one red or green LED on top of Q3 in series if you wanna know the thing is ''on'' at a glance).
- L'Amp: A simple SIT Amp
