no i did not use clipping indicator but i am going to do so .on the over temp issue i used a 0.1 ohm resistor when i connect it the led does not light but when i disconnect it the led lights and relay does not go off . here is my part of the schema
output inductor
guys here is an example of output inductor use in class d amp
It is 1kW SMPS (2 kW peak). Inspiration comes from K6 amplifier K6 700 Watt Audio Amplifier and Switching Power Supply with a few changes and own design pcb.
Heloo to everybody and Happy New Year!
I'm back with new problems.Now i am using lt1016,the rest of the circuit is the same.I am getting more distorsions than with lm311.
Adding capacitance between in- and in+ decreases them(30-200pF) but this means i am using a faster comparator for nothing because it just decreases its speed.
Hello: This is Raj and I am new to this forum. I am also interested to make good Class D amp and searching for this I saw one of JBL LS120 subwoofer's schematic. They use class D which is simple and surely will produce good sound.
Schematic is available here: Keres? - Service Manual finder | ElektroTanya | Service manuals and repair tips for electronics experts
Any expert opinion about this?
Raj
Raj
Please check the link, hope you can view:
https://www.cx.com/mycx/share/PYYgQ0JcEeGSgRICOBql1A/jbl_s120pii_%5BET%5D.pdf
Raj
Raj
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
