900W H-class PA Amp with Limiter
hi andrewlebon,
chestap said there are two type of relays can use.
can u give the relay information of both relays and how many pins,.
other question is can i use black relay for h900 protect board and if u can give pin details to board.
thanks
relay
hi nazirdigi
greetings well for h900 protect pcb the first relay the transparent one
but the relay pins should match pcb no use buying a relay and later find out
its pin do not coincide with pcb holes take the pcb and see if relay pins fit pcb
1 please follow SIR ANDREW T advice VOLTAGE AND CURRENT CAPACITY OF RELAY
warm regards
andrew lebon
hi nazirdigi
warm regards
andrew lebon
thanks for reply andrew t and andrewlebon,
i know h900 protect board not fit to black relay, the 16a transparent relay is very expensive, black one is cheap, can i wire h900 board to black relay?
can u show me how to wiring of h900 board to black relay pins.
if its ok black relay for h900 i can edit h900 protection board .
H900 upgrade
H900 can be upgrade with 15mA VAS current for 3 step class H and add more outputs for more power. I will share upgrades when amp was tested.
Hi apexaudio
greetings nice to see you back on diy forums is it possible to share
h900 with 15 ma vas current for 3 steps as many diyers have built this amp so we can upgrade it
warm regards
andrew lebon
Hi apexaudio
warm regards
andrew lebon
it's a good news
