First post - this is a great forum.
My 97 year old grandfather (who I am very close with) recently moved into a senior apt, and wanted me to have his old cabinet stereo - it's a Zenith MLT-15. Came with a manual, no schematics. Looks like he bought it in '64.
I have some experience with electronics and speaker building, but this is my first foray into both tubes and phonographs (I have never owned a record player before!). Would love some guidance.
The unit hasn't been used much in the last 10 years or so. The tuner works great - no apparent issues other than a few speakers that need replacing, and the volume/balance potentiometer needs to be cleaned/replaced. The turntable appears to be in order mechanically (I recently changed the cartridge and tested all the working parts), but the only sound I get through the speakers is crunchy static. From a basic inspection, it appears there is a separate (and free-standing) pre-amp between the TT and the tuner. There is also an ungodly jumble of wires from TT to pre to tuner - really need to get in and sort those out.
Here are my newbie ?'s:
1. Other than the stickies in this forum, what are some good internet reads for getting my feet wet with tubes and vintage electronics?
2. Any general suggestions for cleaning this badboy up and starting to troubleshoot the phono issues? I've read that replacing the caps might be a good idea?
3. What are some good sources for vintage audio parts and equipment? I swear by Parts Express for most of my electronics needs, but this isn't really their forte...
4. Where can I get a set of schematics?
Even if this isn't a top-quality unit, I would love to get it in fine working order for nostalgia and to finally have a working record player.
Thanks all! This thing just made it to the top of my projects list...
1) Pete Millett's book page has lots of good reading to download for free. Most of it is pretty technical, but there's some more general stuff near the bottom.
Technical books online...)
2) Since the tuner sounds good through the speakers, most of it is working ok including the power amp section. I'd guess that you have a bad cartridge or preamp that I think is solid state. So first verify which is defective and go from there. The cartridge may be an old ceramic crystal type. (perhaps an Astatic) If so, a modern moving magnet type won't work well at all since it's output is much lower.
3) Search engins are your friends here, but Antique Electric may have some stuff.
Antique Electronic Supply
4) The schematic is in Sam's Photofacts packet #685. Folder 14 is the actual Zenith console. You can buy these on line at places like eBay, or download (for a fee) at other places. Google search for them.
Thanks for the help.
So the issue is in the phonograph itself - the pre works, although it doesn't sound terrific. It's an Olson AM-221, looks to be tubed. Could this have been original to the unit?
I would describe the sound from the unit as being "boomy", especially through that pre. This is in part because a few of the HF speakers need to be replaced.
Most of the pots are touchy as well. Is there any way to get to these in units like this without dropping the whole tuner/amp? I expect to have to do this sooner or later, but I'm really worried that It's never going to go back together correctly....
I believe that the '64 Zeniths had the Micro-Touch tonearm. That was about the time that they stopped selling the Cobra-Matic changers.
They originally had ceramic cartridges. The preamp is not original.
Feeding a magnetic preamp into an input which was designed for a ceramic cartridge would probably explain the excessive bass.
You'll need to pull the chassis before you can clean the pots. I use DeoxIT to clean and lubricate pots and switches. It's not cheap but it works very well.
I am glad to hear you are close with your Grandfather and that he thought to give it to you. Mine was 93 when he passed and I treasure the cathedral radio he gave me. Same story, he and my Grandmother bought it new with my mother was but a child.
If the pots are touchy this thing could just need a good bath. The selector switches as well as the pots are highly suspect considering the age of the unit. Try a little spritz with a good quality tuner cleaner. If they are really bad you may need to use a tuner degreaser first and then the tuner cleaner. There were times when I had to go back in and put a drop of light weight machine oil on the contacts to get rid of the noise.
As for the speakers, don't replace them just yet. It is possible to have the original speakers re-coned. It isn't too bad to replace the paper and spiders. The voice coils can be a bit tricky but it is possible to replace them too.
I have a question about the restoration job in reference to the caps. How will replacing the caps affect the value of the radio? Is it OK to just replace the caps or should the old caps be replaced with the same old style cans? Does it make the radio worth more if the old cans are dis-assembled and the new (smaller) lytics placed inside the old shell? I have several other radios I would like to restore and don't want to mess them up.
Good luck and have fun.
Mark
Mark
This thing is a blast already!
Looks like they are ECC83-12ax87's with the diamond on the bottom. One of the tubes looks a little discolored around the top - almost coppery. Is this a sign that it's no good anymore?
It may mean nothing more than it has been used to some extent and may also be the chemistry of the getter used. It is probably OK, IMLE these tubes function well even after a lot of use - haven't seen many that were so bad as to be unusable. Be careful with them, the pair are probably worth more than the rest of the stereo..
It is also not necessarily the case that the tweeters in this thing are bad, it could well be their cross-over capacitors that are the problem. If the woofers are good there is little reason the tweeters wouldn't be. I suspect they are probably small paper-pleat surround types, but might also be small horns. I'm not very familiar with the Zenith consoles of any vintage..
Finally all of the electrolytic capacitors in the power supply and amplifier should be replaced. There may also be small electrolytics and paper caps in both the tuner and amplifier/pre-amplifier that will also need to be replaced. The supply electrolytics and coupling capacitors to the output tubes are the most critical and should be replaced soon..
Sounds like the TT might have been an upgrade and must have had a magnetic cartridge of some sort given the phono pre-amplifier. Early M3D and M7D Shures are valuable these days if that happens to be what is/was on that table.
Thanks for your interest, everyone. I have a feeling I will be hanging around here a lot over the next few months.
The TT is a Garrard Synchro-Lab 65B. My plan is to get the rest of the stereo in fine working order and then come back and address any TT issues - I am so green in both TT tech and tubes/amps that I need to tackle one beast at a time. Most of my electronics experience is in LV stuff - loudspeakers and small motors. Electrical engineer I'm not.
All the pics I've taken so far:
https://picasaweb.google.com/MRaverty/ZenithStereo
Looks like there is a paper cap or resistor by the tweeter - I'm guessing this is all there is of an X-over.
Sounds like the next step is to pull the chassis and clean the pots/replace the caps?
Mike
Mike
Mike, can you try again on the URL, i get "Sorry, that page was not found."
dave
Let me know if this works, I changed some permissions:
https://picasaweb.google.com/MRaverty/ZenithStereo?authkey=Gv1sRgCMq7z8-jwry4OA
Instead of refurbing the table you probably want to just find a better one.
Can you snap a more inclusive picture of the amp, the one there is cutoff just as it starts to get interesting.
dave
My ultimate goal with this cabinet is to get it into good enough shape so that it will reliably play records. Since there is some sentimental value attached to this particular cab (my grandfather bought it 47 years ago), I'm going to do my best to refurb it. I'm more interested in functionality than aesthetics.
Here is the best photo I could snap of the amp without pulling the chassis
Well, actually that is the tuner section. The amplifier is behind the tuner toward the front of the cabinet. And I see a selenium rectifier inside the tuner chassis that will one day need attention. It's the blue thing seen through the holes below the power transformer. When it goes you'll smell something like rotten eggs, and the fumes are toxic. You may also have one in the amplifier chassis as well.
Is there another chassis in the unit? The one with the power-amp, likely 2 or 4 6BQ5 (EL84) + 2 transformers?.
dave
Had to drop the tuner to get at the amp chassis. Pulling the units (and making sure I kept everything documented and in order) was not the easiest thing in the world, but it's done now. Productive Saturday afternoon!
Thoughts? I am afraid I am going to have a hard time finding replacement pots for the volume/balance control... it seems to be a pretty specialized piece (two pots in one), and it's not in good shape. Is it possible to have these refurbished?
Pics are details of the amp and tuner, as well as the "solenium rectifier"
Mike
- Tubes / Valves
- Gramp's Zenith MLT 15
