The Buffalo III Digital-to-Analog Converter
Highlights ... Direct DSD, I2S and S/PDIF inputs supporting up to 32-bit/192kHz...
BIII DAC does not support 384khz/32bit?
then, developing USB transporter does not support 384khz/32bit either...
very confusing...
very confusing...
very confusing...
As for me likewise..
Datasheet of the DAC tells different!
There is no complete kit for that - yet. You would need an input like the new USB receiver, provided it's first iteration would go to 8 channels @ 32/384 (which is unsure).
For the rest, at a minimum you would need:
- 1x BIII + Trident kit
- 4x IVY3
- 1x Placid HD
- 1x Placid HD BP
- 1x 9V transformer
- 1x 15V transformer with dual secondaries
- 4x IVY3
- 1x Placid HD
- 1x Placid HD BP
- 1x 9V transformer
- 4x IVY3
- 1x Placid HD
- 1x Placid HD BP
- 1x 9V transformer
So if I want to do a 4-channel output (since I can't afford 4x IVY boards right now), both of those IVY boards can be powered by a single Placid HD BP? I thought I would have to buy a Placid HD BP and 15V transformer to couple with each IVY board.
Legato 3.1 doesn't suit for that purpose? If yes, than can I use one Placid HD_BP for four Legato 3.1 or IVY3?
Does the BIII accept DSD128FS input signal? I guess in this case DAC should be configured to operate in phase mode. Does a crystal used in BIII capable of that?
The Legato series of I/V stages uses more power, so you would want to make sure packing 4 of those in your case isn't a problem. Also, adapting the IVY3 will take a little less effort (less components to change) and I think Russ stated the IVY3 will respond a little better to just 1/4 of the normal signal.Legato 3.1 doesn't suit for that purpose?
In any case, the IVY3 uses so much less power that you could get away with just 1 Placid HD + transformer, along with the lower price of the IVY3 (compared to Legato with buffer) that's quite a bit of $$ you're saving.
Just confirmed that the current draw for Legato in multi-channel (1/4 input current) configuration is < 30ma (at least as I have it testing right now).
The downside is output impedance is a bit higher (about 700 ohms).
I would likely prefer to use IVY-III for 8 channel work. As its output impedance is always low
Raffle to Raise funds for Doctors Without Borders/Médecins Sans Frontières
Twisted Pear Audio is holding a raffle to raise money to support Doctors Without Borders' relief efforts around the world.
Raffle tickets are $10 each, enter as often as you'd like.
100% of the the money raised goes to Doctors Without Borders.
A final drawing will be held on Wednesday, August 31st.
Last year, Twisted Pear Audio's customers raised more than $10,000 for Doctors Without Borders (here and here). Let's see if we can top that!
"Doctors Without Borders/Médecins Sans Frontières (MSF) is an international medical humanitarian organization created by doctors and journalists in France in 1971.
MSF's work is based on the humanitarian principles of medical ethics and impartiality. The organization is committed to bringing quality medical care to people in crisis regardless of their race, religion, or political affiliation."
Find out more about Doctors Without Borders and their work here:
- More Vendors...
- Twisted Pear
- Buffalo III - flexibility without compromise.
