Has anyone tried a 6S4A as a 300B driver tube?
6s4a is my all time favorite driver tube for electrostatic
headphones. As a 300b driver it should work well, but the
extra voltage it is capable of is very much wasted on a 300B.
2 sections of 6sn7 in parallel has more drive capability and the
300B really wants that when you go into positive grid drive
current.
Propsed Circuit
The input stage is a 6922 yet to be drawn.
Here is my proposed driver.
The output is a 300 B into a 2.5 K SE transformer.
Any comments.
Has anyone got the tools to simulate this circuit before I build it?
Any of the experts out there have a simulation tool that can handle this circuit. :confused:
I would like to assemble this weekend if it looks feasable.
The current sources will be a Supertex Enhancent mode FET.
Power Supply and a 1 minute delay circuit for the B+ are complete and tested, I will draw them out over the next few days.:wrench:
Hi MikeT, did you ever build this amp?
I like the 6s4a (I have an amp using 6s4a as power tube and it sounds great). I also built a 6s4a WOT preamp and I like it.
Am thinking of building a 300 SE with 5687 input tube and 6s4a as driver.
What do you think guys?
6S4 is a good looking triode, but is designed for 150V operation, and a limit of 160V.
Meanwhile the 300B is normally biassed at -60 to -80V, and to allow some margin, the driver must be able to swing +/- 100V. With anode voltage = 150V idle, 6S4 can manage the negative swing, but going +ve, the curves become obviously nonlinear above 200V or so, even if CCS loading is used.
Only high quality option is to try a series cascode, which is what the tube was designed for. IME, an NPN transistor in the upstairs position is best here.
