we need help...
thank u very much......
hello diyers can any one hep us....???Who has the waveform, I want to compare. YouTube - Apex amplifier
try the correct schematic on post 1346
hi,
did you manage to make the transistorized step driver work???...
regards,
ees
Dear Apex Audio, how do I fix this problem?
Hello mile,
Sir, I want to know if your amp(900w) will be any good match to drive the PA horn driver units. I will be driving at least 10-12 of these horns@ 70% volume. Below are the details:
Ahuja Sound Solutions
I will not be using any loudspeakers in the same amp output.
Thank you...
Thank you...
chinese amp stepdrive
hi
greetings most chinese amps have this stepdrive
1 2 or 3 pairs 2sc5200 2sa 1943
2 pair of MUR3060
3 pair of mje340 350
4 2sc5198 2sa1941
step drive trrigered from speaker output
thanking you
andrew lebon
hi
2 pair of MUR3060
4 2sc5198 2sa1941
thanking you
andrew lebon
- 900W H-class PA Amp with Limiter
