NSL32 is opto-ldr, ldr with integrited led diode. There is four pins + and - (litle circle is -) from led diode and two pins from resistor. When led light resistor value incrise and atenuate input signal, that how limiter work. On your picture is just ldr with two pins, U can use this ldr as limiter with clear red led diode put together in black pipe.
is this the same use in shredder machine and copiers. .one is led and the other one is phototransistor and it is activated by a lever between it which blocks the led light thus preventing the photo transistor from conducting.
No, it's not same optoresistor change resistance from 500000ohm to 50ohm, optotransistor just conducting.
Excuse me Sir,is this amp work good??
Do you have the bottom side and schematic??
No respon for this Sir???
sir is it possible for your dc protect to make it stereo and also your short circuit protect so that there will be not too much pcb.should i parallel resistor on 150k and how about the short circuit.what should i add to make it stereo.and should cut the line in middle between those pins of the relay to make it stereo is that possible?
This amp work good, but not for share.
Thank's for your reply...but,can its step driver use for B500?
Hello sir. Thank you for sharing knowledge is very valuable. I would like to learn more about class H three steps. About VERTEX noticed a resistance value of R100 is different. I did not understand the "COUTI"nor the lm082. HER156 has similar?. I want to build the PCB of VERTEX. Will this work? Thanks!
hi sir apex,
i have a trafo, that has a specs of 220v primary, 50v 0v 50v 2.5kw..
can i use it for your h900?
No, but you can use it for B500.
thanks sir,,
i have also a 2 trafo from my old amp 45v 0v 45v 1kw each,
can i use this for h900, pls advice,, i like to build your h900 sir im so interested with this class h amp.
regards,,
Trafo for H900 must have 80v-40v-0-40v-80v.
dear apexaudio
greetings can you please tell bias voltage across emitter resistances .33 in vertex driving stage supply voltage 70 0 70 dc
thanking you
andrew lebon
Set 10mV,
zener diode heating
hi apex audio
greetings yesterday i tested second channel of h900 sound is clear
no distortion but the 15 VOLT ZENER DIODE GOING TO NSL32 IS VERY HOT this problem i did not encounter in any of my h900 i have made before any reason
why this is happening base voltages supply voltages are correct load was 8 ohms output transistors are not very hot normal temprature
thanking you
andrew lebon
hi apex audio
thanking you
andrew lebon
h900 with speaker protector
already on trial, and the results are okay
- 900W H-class PA Amp with Limiter
