where wrong?
Can you post your pcb design in pdf ?
I have email u.
The PDF file.In the pcb I connect the out to out,connect the pgnd to pgnd.
Emiter of Q7 is not connected to base of Q9 on your pcb.
thanks thanks thanks thanks.... ....very good sound,like the sound
What speakers you use with this amp?
C1-Nichicon muse 10uf
C7-CDM 47pf ,C6-BC 038 series 100uf,bias-100ma,a pair 21193/21194,DC +/-24V,100W transformer
would be 5401 instead of A970 better?
I like warm sound,any advice for me?
can it work at class A?
2SA970 is better than 2N5401, bias 100mA is OK no need to go in class A.
Nice work, is this diy case or you use some from brand amp?
These cases are readily available at the local electronic suppliers here in the city, there are different sizes, with the holes ready made for volume control, tone control, on/off switch, input and output, fan, fuse... I just asked for one about 30 cms wide and depth, without tone control holes. Looks very professional
Luigi
Hello Mile,
Will you guide how to set the bias , I have never done it before.
Thank You
Set 20mV on 0,33R/5W for 60mA.
Sir Mile... Please cek my design APEX-B50
Zeners must be connect to 1k/2W not to rails...
- 100W Ultimate Fidelity Amplifier
