Acoustat Answer Man is here
Now, here's a question - there was an outfit in Florida that was making replacement transformers, do you know if they or someone else is still around??
See bottom of products page for prices on replacement Medallion transformers from Russ Knotts.
products
Excerpt >>>
All New Acoustat Medallion Bass step-up transformers each built by us to Acoustat Medallion specs $225.00
All New Acoustat Medallion Midrange step-up transformers each built by us to Acoustat Medallion specs $125.00
Hello Andy!
Great to see you here!
Could you maybe offer some insights as to what high current amps from new era or say less than 10 years old you would select to run Acoustats. I have been running just one 9" panel per side with bone stock Mk121A interfaces from a pair of Model 3's. I did not move the bass tap either. The single panel per side has limits of course but sound just right IMHO and the beaming is much less. They actually make rather astounding amount of deep bass. A difficult load though it would seem. Just one panel by itself is supposed to be tougher than multiple panels on one interface. Using a mid 90's Harman Kardon PA2400 and it runs the dickens out of the Model 3's as well as one single panel per side. Tried running the single 9" panel with a mint condition Krell KSA200s and the auto bias ramped up lit the front panel up like a christmas tree and she went immediately into protection. The Krell basically said "fuggedaboudit". The HK with 170wpc however runs them just fine. Sounds delicious.
Anyway I'm considering the Frank Van Alstine offerings since he is known for fixing and modifying Hafler high current designs and has several of his own designs rated into 2 or 1 ohm loads. avahifi - Power Amplifiers Comparison Grid
Any other recommendations for a more recently manufactured "high current" design that won't break the bank? I had thought about Pass Labs also but I would be pretty disappointed and suffer having to sell the thing if it did not work. Expensive decisions.:scratch1:
Hey Andy
I presently have Spectra 22s. I have been able to acquire the parts (extra panels and Spectra 44 /66 transformers) to build a Spectra 44 .Only problem I have is that the room that they have to go in does not have the height necessary to stack the panels as in the 44 and 66. What I was thinking of doing is placing the 4 panels side by side .Is this something you have tried? Should I be moving to a new house?:D
Andrew
PS here is a link to some construction pictures of Acoustat panels in heavily reinforced steel /wood frames.
Canuck Audio Mart • View topic - The making of modified steel Acoustat's
Andy, any info on how Acoustat tested regarding the angles of the panels, particularly the 4 wide speakers? Also, how important it is to mix 8" & 9" panels vs just going with 9 inchers in a Model 8 / 4+4 type? I'm planning to build such a speaker with all the extra panels I've got. Thanks!
The angle-between-panels varied over the years, with some of the later models (i.e. 2+2) having less angle than an earlier Model 4. I believe the final angle was about 9 degrees between panels. Of course the Spectra Series had no angle between panels, since the panels were electrically curved (convex when viewed from either side!)
The combination of 8" and 9" panels was an effort to 'spread-out' the low frequency resonant point, the 8" being a slightly higher frequency. If all you have are 9" panels, I would not let that stop you from building a Model 8-like design. Note that the 8" panels were used only in 3-panel and 4-panel wide systems, like the Model 3, 4, 6 and 8. The 2+2 and all of the larger Spectra's (even the mighty 66/6600) did not use the 8" panel.
Atom, The spectra panels are intended to spread the HF from the center out... so assuming that the center panel has enough HF dispersion then in theory anyhow only one panel should be run as full range... the others not... otherwise the whole idea is somewhat out the window.
Otoh, 4 side by side is an Acoustat IV which is quite good, and has the deepest bass of the side by side versions.
In practice it might make no diff if you run them as spectra, or tie the stator wires together. The replacement cells I got were spectra cells, and I just tied the stators together in my IVs and IIIs...
_-_-bear
Speedracer - the hands down best amp I ever ran with my Acoustats was a highpower tube amp with a pair of 811a in the output running @~1100vdc B+... for whatever reason it made all the solid state things ever tried, even my 128lb Symphony No.1 sound thin and anemic by comparision.
Also, consider a Strickland designed TNT 200 amp?? It can use some upgrades and mods, but more or less it is designed to work with the Acoustat amps...
_-_-bear
_-_-bear
Only 1/2 of one panel width is run at full range in any Spectra model, the rest of the panel area is mid/lows or lows only. Spectra panels can be used in non-Spectra applications, and I consider it optional to tie the ends of the split stators together. Connecting both wire leads together (white-to-white and blue-to-blue) will make the stator all the same circuit.
Hello Andy!
I'm using a Hafler 9500 with my Spectra 4400's, and find the combination very satisfying. Any of the later Hafler's, such as the 9500 or 9505 (w/balanced imputs) will work well, although they do not qualify in your quest to find something 'less than 10 years old'. BTW, Jim Strickland designed the Hafler 9500, and it is a further refinement of the original Acoustat TNT-200. I have used the TNT-200 as well, and I consider the 9500 a significant improvement.
Sure Andy - but the question is IF the distance between the two HF sources, that being the 1/2 of the cell to the adjacent cell's 1/2 cell is more than or multiples of a 1/4 wavelength, then the potential for nasty horizontal polar response comb filtering exists. That's the concern I was voicing.
_-_-bear
PS. can you post a copy of the 9500 schematic up here?
Here is the schematic for the 9300/9500. Quite the heat generators even at idle as I recall.
Thanks, Andy. What I'm planning on doing is building some sort of framework to hold a 4 panel-wide array which has the ability to allow the panels to have some rotation in order to try and ascertain the best panel angles in my room. I was curious if Acoustat did something similar to arrive at these angles. I have a few ideas in mind, but if there is an existing way of doing this I'll take that under advisement. The plan is ultimately to determine the best angle results from the adjustable 4 panel framework, then build a double-height (8 panels) rigid frame (braced to the ceiling) from these results. Any thoughts?
I used piano hinges, the length of the cells, with a thin MDF strip the length of the cells, but only as wide as the "dead" area on each edge to mount the piano hinge to... not perfectly ideal, but it did work nicely for my "space frame" Model IIIs... I did get a deal on very long piano hinges... and in the III the center panel is fixed rigid mount... it does get the cells closer together than the stock frame can.
IF you take the acoustats outside, you will likely find as I did just how beamy they are!
With no walls or ceilings when you get off axis you really really hear the highs drop off... inside, not so obvious at all. Was kinda surprising when I did that... and it was on earth not on pavement of any sort, so kinda dead...
Oh, hold on...
Wait a second...
My name's not Andy! :D
_-_-bear
What a nicely drawn schematic, if I don't say so myself (I drew it!). Yes, the amp does run toasty even at idle, and even hotter when driven hard. However, the heatsink capacity is very good, and despite driving my 9500 very hard at times into Acoustats, it has never gone into thermal shutdown. And that's with a Hafler 9180 stacked on top of it, that I use for in-wall speakers in other rooms.
The design certainly represents the pinnacle of acheivement in amplifiers from both Halfer and Acoustat, as it uses lessons learned from previous products at both companies. For those of you who don't know, I started my audio career at Hafler in 1982, when the only products were the DH200 amplifier and DH-101 preamp. I moved over to Acoustat when Hafler bought the former. So you could say I know a good bit about Hafler products, too.
Oh, hold on...
Wait a second...
_-_-bear
Bear - I have NO problem with you providing answers to any of the questions directed at me. You probably have more experience with experimenting than I do, whereas my experience is more with Acoustat's product design, manufacturing, and after-sale service. I was directly responsible for the electromechanical design and final voicing for the entire Spectra line. Basically we kept Jim Strickland locked in a back room (not really) where he could dream up new and exciting ideas. It was my job to take those ideas and turn them into manufacturable, sellable products. Ahhhh...those were the glory days. Sure do miss 'em. My current job as a general manager of a precision sheetmetal shop just doesn't quite offer the same satisfaction. Oh well, many people never get to experience that kind of job satisfaction, so I count myself among the lucky ones who did.
Reactions: 1 user
Hey Andy
Andrew
Acoustat never made a 4-panel wide Spectra, even as an experiment. Sure, we dreamed of making a 'Spectra 8800', but the sales potential of such a behemoth was never great enough to consider it worthwhile. The number of Model 8's that were produced were very low - probably less than 50 pairs, maybe way less.
However, your idea is worth considering. Basically what you would be doing is adding two bass-only panels to the outer edge of your Spectra 22's. You'd want to use the transformers designed for the 44/66, with the bass tap set for a 44. However, unlike the 44/66, you would probably want to keep the same values for the high voltage coupling resistor, capacitor, and the sector resistors. This is because you would still have the same panel area devoted to full range and mids as your Spectra 22.
The height of the tall Acoustats probably did limit sales somewhat - if they had been a few inches shorter, Acoustat could have fit into more homes.
Good luck with this project - sounds like an interesting concept!
I personally prefer the sound of the 4 panel wide arrays, but I got used to the 2+2 and can't live without the full height sound. My room doubles as a gym so single height Acoustats don't cover my ears while laying on the ground and standing, so I figure a 4+4 (I'm calling my project a Monitor 8 since I'm using Servo amps) gives me the best of both worlds, plus extra bass extension.
Andy, no problem... you certainly have information that I just don't know anything about at all...
hella, I did not end up with an angle! :D
The whole idea was to have the "wings" be adjustable. Which they are. In practice I think I ended up using them at an angle that was similar to the factory frames. Although I did at times angle the inside cells a bit more than usual to get better imaging (you "see" mostly the center cell) without losing the bass and mids... but that was somewhat specific to my particular room set up (more than 2x longer than the width at 14' - but the listening position varied between ~ 10ft back to double that or more...).
There's not much to look at with them as I never really got the thing to a finished state, although it is/was functional. When you look at it is is 3 cells more or less floating in air, held from behind at some distance by a frame... with the spectra cells in place there are a lot of wires dripping out the bottom! :D I did put one set into nice silvery woven sleeves... better.
_-_-bear
