Yes, if the thickness is 15 to 20 mm or more
A Faraday cage is an electrostatic shield. It's the conductivity of the material that matters much more than thickness.
Thickness counts more for magnetic shielding, along with the permeability of the material.
se
Eddy currents, Steve, you should have known them.
The assertion was about Faraday cages. Electrostatic shielding.
I am using something similar, but with passive 75uS eq after the first stage
That's same or similar. 1st stage is linear 20dB, followed by Tau3 (i.e. 75us).
On my MPP thread i have posted a lot of circuits that did just that. Linear amplification
( i prefer 30dB out of some reason ), 75usec pole passive ( actually i do prefer the transimpedance version ) and then active equalisation of the deeper frequencies. I think it is a very good recipe for success.
Buffering Opamps well does work fine too, so Pavel, i like your block diagram.
Eddy currents, Steve, you should have known them. And penetration depth.
As SY reiterated, we're talking about electrostatic shielding, not magnetic shielding.
It's magnetic fields which create the eddy currents which are responsible for absorption loss in magnetic shielding.
se
Thanks 2 quad, yes there is a lot of 'snake oil' in this business, but not EVERYTHING is 'snake oil' any more than Asian medicine or holistic (sp?) medicine is completely bogus. In fact, I recommended to my boss, just today, to check out Chinese Medicine for his problem, since the hospital is not working out. Why not?
snake oil is wonderful stuff
there's been more people cured by snake oil
than all other medicines combined.
Does anyone know what words often go before one of the stupidest statements you will hear that day?
"I am an engineer and I know that...."
Looks to me like the Audio Note preamp is using a lead free solder. They do not flow the same as leaded solders. Folks who try to make lead free solder connections look the same as lead based solder ones end up with poor joints. I am an engineer and I know that because I set up test boards with different solder types and techniques and measured the results.
Military specifications work for the military needs, doesn't mean they are correct for other applications.
As to a 94 pound case, it probably started as a solid chunk of plate and was milled out. So the 94 pounds started as at least 400 pounds at $3 or more a pound just for the metal! The machining cost would depend on how well equipped the shop is. I have seen some truly impressive shop work out of California shops making audio cases. Much better than I know how to do. Never seen anything close in terms of quality even from Europe. A significant advancement over the Westinghouse guides.
BTY Boeing now uses the same technique to make parts as big as wings! Really Really big milling machines. Of course they remelt the scrap! End cost is supposed to be the same as the older welded or riveted versions.
Thickness counts for Al and Cu very, very much, when we speak about lower frequencies.
And besides a CU chassis would cost much much more. A solid billet of copper alone but the machining is far more difficult.
Yes, aluminum shields RF better then copper.
Please reconsider this, Joachim.
It is al matter of conductivity and permeability.
For some who have already contributed, please study the basics at
Eddy current - Wikipedia, the free encyclopedia
http://en.wikipedia.org/wiki/Skin_effect
Dennis Morecroft in England ( DNM ) uses as little metal as posible so there is a skool of thought that any conductive and permeable material should be avoided near the circuit.
This sounds a bit like snake-oil, Joachim, especially if the material is not heavily non-linear. Copper surely does not "worsen" sound. Probably he might like EMI induced into the circuits - some really do prefer less defined sound resulting from more interference.
- Member Areas
- The Lounge
