Only for fun, Obbligato's in Salas Low MC Phono RIAA photo:
Looking good.
Looking good.
Thanks, really the Obbligato's looks nice.
I particularly like the big smicas.
How does it sound now ?
Now thin sound, very clear, of course need's more break-in to open the highs & go down the lows. It's like I supposed very similar sound to Hovland aluminium film & foil.
It seems to me after Merlin's reports on film caps and regs that in his system mostly ''rounder'' capacitors work better for him. I am suspecting his speakers and acoustics being the arbitrary decisive link. Was listening to double mono 1.2 full plastic caps regs just yesterday on the phono, and the tone is so clean, resolute and melodic in the same time. I wouldn't dare to recommend Ampohm paper in oil or Mylar in oil, under extinction and so huge, or Jupiter Wax, because such experiments are expensive, and without witnessing a system we can't really know more. I trust Merlin is experienced and knows his tastes so he decides his voicing best. By the way, he has gone a long road from his first frustrating attempts fast, and he makes now remote sensed regs without assistance, silent phono stage, tunes voicing, we must congratulate his dedication.
All film caps test was using headphones HD600 not the speakers, I know perfectly mine speakers sound, if I will use the phono RIAA only with the headphones surely Obbligato's would be mine first choice, but Wilson Cub is another history: sounds more directly & not forgiven any kind of harsness & tell us how is bad or good for the speakers, I know also that I have acoustic node problems between 150Hz-200Hz as usually everybody has, but with headphones not matter.
N.B. every hour Obbligato's are sounding better
Thans for your kind words, surely warm & round oil caps souns well with the Wilson Cub, I remember perfectly when I used Audionote DAC's with paper in oil Jensen caps that where replaced for Auricaps but the problem with Audionote isn't the coupling output cap, the problem is the tube output & the low gain of non oversampling AD-1865-NK.
First of all thanks all of you about this topic!
I'd like to try build this riaa and I have couple of questions.
I use MM cartridge so what's the newest schematic for MM riaa and newest shunt psu?
I'm on page 211 and is found some schematics, to MM riaa page 182 and shunt page 25.
Is the r6 mod now on the shunt psu schematic?
I'm trying to understand what I have read, but I'm beginner on these..
Thanks!
-Jake
Thanks!
-Jake
Thanks!
-Jake
Don't worry Jake, simply follows all the Salas advices & you do it like me.
The "massimo simplistic star ground" works like Messi
Not very good then......
1-0 (and a clear offside)
P.S. It's only a game and not serious staff like audio
- Analogue Source
- Simplistic NJFET RIAA
