A 12AX7 normally biased will not pass enough current to run a normal LED in its linear region. You will have to supply extra current (approx 6 - 8 mA) from a stable source.
Advantages: you lose a cap and a resistor, and some say it sounds better.
Disadvantages: you require an additional source of stable current, and some say it sounds worse.
What are the advantages of using, say, a red LED for cathode biasing for a 12AX7.
Linearity, lower cost.
What properties would one associate with using diodes instead of the typical resistors?
Good sound
Yes. A CCS should work very well here.
There are some High Efficency LEDs that will work at much lower current levels than previously specified.
For instance the LGT67K ("Hyper Bright Low Current LED", Yellow-green, Osram) is specified for operation at 2mA and data is available down to 1mA.
The LGQ971 is specified at 20ma, but if you read the fine print that is pulsed for 25ms. Typical drive is 2mA (or less) continuous. These LEDs begin emitting light as low as 50uA in the linear regeon of the curve starting as low as 1.1V forward bias.
Similarly the LST670 (Super-Red, also Osram) is specified at 10mA, Luminousity data data is provided down to 1mA, and If/VF data down to 100uA.
The 20mA spec for the LGT67K puts them in the knee of the curve above the linear regeon.
I stick with operation in the linear portion of the curve at much lower current levels.
I'm using the LGT67K LED in my "FireFly" SET (Single Ended Tetrode amplifier, Schematic soon to be posted) I'm designing for my wife to use as a replacement for her present self powered speakers on her computer.
Unfortunatly many new inovative components are available in surface Mount only, and rely on heat spreaders on the PCB to handle thermal dissipation. The LGQ971 only dissipates 4.3mW at 2.9mA (6NP1 bias for the input stage) so it is not an issue with this device.
AFAIK a diode (whatever it is) is always a non-linear element. Current through the LED isA 12AX7 normally biased will not pass enough current to run a normal LED in its linear region.
i = is * [exp (U / Ut) - 1], where Ut = kT / q
It should not make any difference what kind of LED (low-current or standard) you are using, assuming all other parameters are equal.
I believe they meant "constant" (as in: constant Vf) region, which appears as an almost straight vertical line at V = Vf. Granted, it's hardly linear, and besides, what use would it have to replace the most linear element out there (the resistor) with another ?
Back on topic: I use the cheapest LEDs I can find in local electronics stores, I specifically ask for "cheapest, low luminosity" ones, red for 1.75-1.8V and green for 2.0-.21V. These are usually the dull-glowing type with diffused bubble and work well from few mA upwards.
High brightness types usually have much higher Vf and require more current to reach the region where Vf is relatively constant.
Yes, I know what you mean. Unfortunately there is no "linear" region in the diode characteristic. Because of the linear scale of the i-v curve it looks only like linear. When you are using a logarithmic scale there is no bend regardless of the current or voltage.I believe they meant "constant" (as in: constant Vf) region, which appears as an almost straight vertical line at V = Vf.
When biasing a LED higher than 5 to 10ma the internal resistance has to be taken into account. In this region the LED becomes more and more linear as the internal resistance linearizes the current dependant conductance of the LED. Maybe this is the intention for the additional CCS.
I cannot see the reason, too.Granted, it's hardly linear, and besides, what use would it have to replace the most linear element out there (the resistor) with another ?
The LED actually replaces a cathode bias resistor and its bypass capacitor. Obviously there is no -3dB corner in the low end response due to RC rolloff. Overall the LED generally behaves more linearly than most electrolytic caps in this application which is why the use of LEDS for this application has become quite widespread.
I was sceptical, but have used LEDS in applications where very large cathode bypass capacitors (1000uF) would be required at very low polarizing voltages (say 1.5 - 2.5V) - something that I have found not to work well. (Think of 7788, D3A, 5842, C3G running at high currents resulting in very small cathode bias resistors and very large electrolytic caps)
If you use a CCS plate load (an excellent idea for a 12AX7), the LED will work fine as is. See my recent "Guess the Tube" post.
Sy,
very interesting that your usual 'resistor trick' made no difference at that low a current. I don't discount your result given that it was based on careful measurement, but rather counter intuitive based on log-lin I-V curves (linearity definitely appears better and dynamic impedance lower at higher currents for the ones I can remember). I wonder if the result may have been slightly different for a lower resistive plate load?
Were you using HLMP6000 ?
Mach1, remember, current is constant, so the dynamic resistance isn't varying either. There's a great synergy between CCS and diode bias.
Yes, using an ECC88. Under static conditions (no overload), no difference in the distortion spectra.
Has anyone compared the two?
That's what I was alluding to. In a conventional case where a resistor is used as a plate load (there was no mention of a ccs in the original post) there may well be some benefit in injecting extra current to place the led operating point on a more favourable portion of the curve.
Which current is this ? Constant anode current (= CCS load) does by no means equally (AC) constant cathode current and it is cathode current that dictates the bias voltage (Vf).
Nevertheless, I don't think any sane person would drive the Ik out of constant Vf region operation when using LED bias, so CCS shouldn't make much of a difference when stacked against regular 50-200K-ish load, unless it was deliberately built so that Ik(q) exceeds the suggested operating point (which might be a sane thing to do, those suggestion are often - mildly put - very wimpy, and only take purely resistve load into account).
Blah, enough ranting, time to go to sleep
What Arnulf says is right for the majority of cases.
However if we use a mu-follower configuration the cathode current variation is usually very, very small, hence the LED resistance variation is also very, very small.
Also, in a parallel feed configuration I understand that the 'return' can be made directly to the cathode (i.e. prior to the LED) so that the sum total current through the LED remains constant.
As has been said, always refer to the datasheet graph (forward current vs voltage) for indication of resistance at your chosen operating point. There is a vast range of LEDs available, so there is always something to match your application. A good selection of LED datasheets are available from RS Components (...you have to search for the product first, and then access the datasheet from the product page).
Hi! I would like to learn about SY's "resistor trick".
Can someone point me a link that illustrates the issue?
Parallel the current source (tube) with another resistor to provide sufficient current for cathode LED to operate in "constant" Vf region.
Unless you're drawing grid current, yes, it does, forced by Kirchoff's Law.
- Tubes / Valves
- Using diode for biasing
