thanks for the replies everyone and thanks for the measurements saturnus - i'm sure you must get bored of talking to ignorants like me who keep asking stupid questions!
i've been thinking about things a bit more and re reading the thread and takign notes and apologies for thinking of murdering aperfectly amazing, finely tuned design, that i have no real brains to do but the heaviness scares me and i can't find another design i like as much that weights less....
so it seems like i can't do much about the Q without paid for software which i don't have so i'll just have to ignore it i spose and maybe make the gain graph a bit more peaky!? ( as liek the alphalite shown below )
i think i found two potential driver / box combos that will be lighter for me, ( at the cost of loundess ) but want to ask if anyone can see anything obviously wrong with my results. just so i know if the last three days and nights have been any use at all ...
the two drivers i think might be able to do it for me are the:
- eminence alphalite 6a ( weight 1kg each - saves 8.6kg w/ four, depth 61mm, cost £65 each ( ouch !! )
- fane sovereign 8-125 ( weight 1.75kg each - saves 5.6kg w/ four, 94mm, cost £25 each (better! )
i got the frequency response graphs of each and overlaid them on the one for the HP10w to see how they compare. that image should be here.
The black line is the alphalite 6a, red is the fane 8-125 and the blue is the HP10w.
it seems to me that the alphalite is pretty good in this comparison but the fane seems pretty patchy because of it's wildly changing output and -3db drop as it goes from 80 to 100hz and the 4db hole in the 130 to 180hz area. Could it really be this bad? - would they sell something that looks as messy a response ( i got it from their catalogue !?)
the reason i am asking is that in WinISD it looks much better than the alphalite when i compare them both to the hp10w
here are the gain curves
and here are the volume curves with all three.
( there are two drivers in each box and they are getting 10w at 1m )
the fane one is doing what saturnus said of peaking at twice the frequency of the box tuning, whereas the alphalite definately is not and it also has a very steep curve at the low end which might not have enough bass? It is however at -3db at 100hz like jimtegel just suggested.
i know they're not as loud - i'm prepared for a bit of a drop in volume in exchange for weighteasi, i need to be able to move it around easily on a bike or i won't take it w/ me in the first place!
and even if the alphalite is ok i also have the problem of the alphalite being way to shallow - i wouldn't be able to stick them magnet to magnet and have a square section box - but i could put a light block in between to keep the strength idea - loosing the magnet to magnet 1/2 db gain.
anyone any thoughts? ( you can tell me just to shut up and build the original and get stronger legs but i might cry! ;-) )
cheers,
simon
cheers,
simon
Ok, thanks I am still considering making it with four speakers as the original design to get the best possible soundsystem. Just wanted to hear in case I'm short on cash.
Saturnus: Is it possible that the sketchup-file could be reuploaded? I can host the file for at long as you want. Just email me the file at xanroar@hotmail.com and I will post a link here in the thread.
HP10W 4 ohm
Saturnus:
You mentioned that you had found the HP10W drivers in the 4 ohm version. I've been looking around for the name HP10W4, but the only hit I get is an australian webshop which have them out of stock. When I mailed Intertechnik, they said it wasn't possible to get them to carry them unless I agreed to buy 100 pieces.
Is it possible that you could provide a link to where you found the drivers?
Saturnus:
I think we have settled for the final design of our new boominator, but still a couple of questions remain, which I hope you (or other followers) can answer, since you know the internals of the boominator.
1. I still haven't been able to understand how we should wire up the Amp9 to the speakers. My problem is that it has 4-channels, while the 4 speakers of the boominator serves as only 2 channels since they are paralleled. And I think I've understood that if you bridge the 4 outputs into 2 outputs, it will double the resistance from 4Ω to 8Ω on each of the two resulting channels. But since the 4x8Ω speakers are paralleled, they will act as 2x4Ω speakers, which the amplifier wouldn't like when bridged. So...how do we wire the outputs to get the full power from the amplifier into the paralleled speakers?
2. I've seen you mention the Sure 4x100W amplifier on the Roskilde-forum, and we are very tempted to go with that instead because of the more power and cheaper price, but do you know if it has any significant drawbacks compared to the Amp9? Sound-quality is not important. Our main concern is power consumption(efficiency and idle), heat, and if we will be able to use all 400W into the 2 (2x2) speakers.
3. Will 2x 12V SLA's delivering a max of 2.1A each, wired to 24V even be able to drive any of these amps? Tried with an online calculator which says that 24V and 400W will draw 16.67 Amps, which sound like an awful lot to me.
These are the only two questions remaining before we will begin ordering parts, so any help will be very appreciated
Pictures are always good, so here are a couple of our Heime v.3 from Camp Fri Ost @ Roskilde Festival 2009:
If heat is a concern, dont go with the sure 4 channel amp.
You might however try the 2 channel version, which can deliver 100w per channel into 4 ohm, so you could just put 2 speakers parallel to get that.
Dont bridge the 4 channel nor the 2 channel version, they WILL die (or just leave a hole in the pcb)
Wow thanks for the quick reply!
My guess is that heat will be a concern since it will be put inside a small box within the boominator. Do you think the 2-channel version will be cool enough without a fan?
And when you say that we shouldn't bridge the 4-channel, does that include the Amp9? Cause the 41hz website says:
"Outputs can be paralleled for even higher outputs into very low impedance loads"
If the Amp9 is capable of that, this amp would be the one to go for if we want a louder boominator, right?
You can either go for PLLXO and use the 4 channels the best way possible or you can "just" wire it up as you say with the 3 units per channel equaling 4 ohms?
You need to know some things about the amp9. At 24v it can run 4ohm speakers and generate up to 100watts per channel. at 12-14,4v it can run 2ohm speakers with no problem.
You can even parallel the inputs and outputs 4->2 channels to run 2ohm sources at 24v for 200watts per channel.
The sure is worse at powerconsumption than the 41hz amp. It gets hotter and sounds worse (although not bad, just not as good).
With this high effeciency design that saturnus has made, the idea is actually not to use power and money on high wattage amps as the speaker design generates high SPL at low power levels (high power also equals more aH batteries). Maybe you should try the ta2024 T amps first as they idle much lower than the taa4100 and sure 2050 amp.
Alternatively you could go for something like the amp4 or sure 2050 2x100watt which sits in between the 2024 amps and amp9.
The amp9 peaks at 11A as far as I remember but you will likely never see it happen as music signal does not contain all frequences at once. Does your SLAs really only deliver 2.1 amps? I use 12v 7aH gel lead batteries which are rated much much higher in short term power delivery (as engines crank). 2.1A is not enough and you might destroy the amp fairly quickly
The sure cant be bridged, it is already internally bridged.
I dont know for the 41hz amps.
You might take a look at the amp 11, as it can power 4 ohm loads, but its a mono amp. You will need 2, and it seems it is a hard amp to solder.
DO NOT put the sure 4 channel amp in a case. It needs at least a fan when powered above... well... almost any working voltage
If you want really high power, there also is an amp 11 HV version, up to 200w output/channel. Again, it is a mono amp...
excuse my incomplete info but i'm pretty sure ( enough to risk posting ! ) that bridging and parralleling are different.
see here for a thread on paralleling the amp 9 as i don't know it well enough to explain it!
Anyone with experience paralleling Amp9 outputs?
hope that helps a bit...
Alrighty, I'm not building any of this stuff but the projects are interesting and I pretty much scanned the whole thread. I saw almost no circuit drawings. Lots of talk about box alignment and tweeter crossovers, but didn't see anything about woofer crossovers.
Folks will want to be sure they have not omitted a high pass filter for the woofer. If your port frequency is at 70Hz, for example, you might want to use a 24db rolloff below that, maybe 60 at the lowest. Where to crossover would be a compromise between sound quality and energy efficiency, and filtering right at the tuning frequency might not be a bad idea, but ignoring a high pass on the woofer when you're losing response in truckloads below 60-90Hz might cost you half the running time in waste heat in the woofers (and lots of dynamic headroom as well, depending on the signal.) Of course you want this to be a signal level crossover of some kind to keep low end that can't be converted into sound pressure out of the amplifiers altogether. Please excuse if this consideration has already been addressed across the board and I missed it.
AMP-1B is also a cheap high power solution, but test first if it is needed.
Bridging and paralleling are NOT the same thing. The amp9 is also bridged internally so only way to increase power is to parallel and half the resistance of the speakers.
@ andrew
Do you mean a bandpass filter for the woofer? I didn't quite follow this "but ignoring a high pass on the woofer when you're losing response in truckloads below 60-90Hz might cost you half the running time in waste heat in the woofers"
@ andrew
I've tried to look at PLLXO, but it seems a bit complicated. I guess the point is to have tweeters on two channels, and woofers on the other two? Anyway, I hope we can just go with the original design where tweeters and woofers are on the same channel to simplify it for us noobs, hehe.teamacc said:You can either go for PLLXO and use the 4 channels the best way possible or you can "just" wire it up as you say with the 3 units per channel equaling 4 ohms?
Sounds like there are quite a lot of possibilities with the Amp9! That's good to hear. Does this mean that we can parallel the ins/outs getting 2x200W into 2x 4ohm speakers?teamacc said:You need to know some things about the amp9. At 24v it can run 4ohm speakers and generate up to 100watts per channel. at 12-14,4v it can run 2ohm speakers with no problem.
You can even parallel the inputs and outputs 4->2 channels to run 2ohm sources at 24v for 200watts per channel..
If we could get hold of 4 of the HP10W 4ohm version we could even get them down to 2ohms/channel by paralleling the speakers AND channels, without destroying the Amp9? I imagine that would get pretty loud .
Wow...this is quite advanced for us, concidering that all we want is to make a boominator that just plays louder than the current one with an Amp6-B (which was still a bit advanced for us, ).
I'm SO glad you guys are helping us with this!
Good point on the high-pass filter for the woofers.
That is fairly easy to accomplish by adjusting the value of the input caps on the amp, since they're there anyway. I think most people are doing it that way rather than doing something with post-amplification crossover components.
Not sure what the numbers say, but I think you start seeing roll-off in the bass somewhere around 1uf or so. Anybody done the calculations/measurements?
--Buckapound
--Buckapound
Okay thank you! I think we will try to avoid the Sure ones. I think I read that the 2x100W also gets quite hot.The sure cant be bridged, it is already internally bridged.
The 2x Amp11 is an option yes, but it is a bit more expensive in total, and even more stuff for us to break
Sorry if this is a stupid question, but bridging is where you solder some components together on the board, and parallel is just when you use two output-channels as a single output?Bridging and paralleling are NOT the same thing. The amp9 is also bridged internally so only way to increase power is to parallel and half the resistance of the speakers.
If so, we can parallel the outputs and leave it there, I think. We are not able to lower the speaker resistance, since they are already paralleled in pairs. (4x8ohm into 2x2 @4ohm).
- Class D
- The Boominator - another stab at the ultimate party machine
