Actually, depending on what type of SMD caps you are talking about, higher voltage might be better.
For exampe, my cap of choice right now is 1uF 100V X7R ceramics (mainly because I have a few thousand). The high voltage rating helps minimize some of the "nasty" qualities of ceramic caps that often make audiophiles cringe.
I can series/parallel these for almost any value I need and still keep the size down to only a fraction of what a bulky film cap would be.
I use these now, sound is excellent (as they bloody well should be at that price). The tolerance just means you have to buy several and then match them which isn't a problem since you have to buy a certain number of SMD at a time anyways. As a rule of thumb, take the tolerance number in percent and multiply with the number you need to be roughly certain you have enough to match them well.
AVX|CB038B0154JBA|CAPACITOR, 150 NF, 16V, 1812, | Farnell Danmark
You can get far cheaper ones though from Wima or Panasonic but these are the best ones I know of at all.
You can get PPS caps in the uF range as well, though they are tough to find.
Also, you have to be careful soldering these by hand; they melt very easily.
Yeah, I forgot to mention that
Luckily you always have a few spares (since you have to order a lot more than you need anyways).
I should note that these are the best input caps I have ever heard, btw, they beat everything else regardless of price. It's not that they're PPS in itself but that these just seem to be the best input capacitors at all.
Soldering definitely isn't a strength of mine and those little caps without leads terrifies me. Would these wima caps be a decent alternative? Seems like it would make for an easier soldering session on the sure board.
Electronic Components & Supplies
Hey everybody,
I've read and re-read this message thread and like many of you, have the bug to build one. Hats off to Saturnus for the skillful design work and for sharing it with us.
I like the design details of your Boominator, Saturnus, and with your permission plan to pattern mine off of your design.
I'm from the USA where I can't seem to locate either the HP10W or the Zomax HP100 piezos. From this thread, and a review of the specs on the partsexpress website, I understand the GW-1058 to be a suitable substitute for the HP10W. I read the discussions about a few other tweeters, but didn't see recommended a substitute tweeter that's on par with the HP 100.
Do any of you have a recomendation for a good-sounding tweeter like the HP 100? Is there an even more efficient speaker than the GW-1058 (with appropriate specs) that is not too terribly expensive?
Thanks, Bill
Thanks, Bill
You guys will probably like this my mobile disco:
It sounds awesome, is really loud and runs for hours. The trouble is its a bit fragile because i rushed it to get it working for this festival.
That is awesome! And it looks like you've attracted the right kind of crowd too
It's not because I wanna be to inoying. but I would be very happy if one of you guys want's to tell me how I maybe could make an okay Boombox that would be able to last quite a while. im probably the only one with this question in this tread.
But I would be so happy and there would also be a camp at Roskilde and Jelling that would be so much better
From a hopefully Buddaertyk.
Hello Saturnus. We've build a Boominator for Roskilde 09, and it was a huge success. This year we are planning on making it a bit more powerful, so I have a couple of questions to your planned changes for your new Boominator.
I'm looking forward to see the new Boominator!
What effect will this have?I'll be making some minor changes though, like adding a phase plug with a rod that will connect the 2 speakers mechanically through the center.
I've been thinking of doing the same, but do you know if it will be as easy to implement, as the Amp6-Basic? I think we are going to have it build for us, so I'm talking about if it will work 'out-of-the-box' with two 12v batteries in a similar way to the amp6-b.The amp6basic is going to be replaced with an amp9basic
What impact will that have on the performance of the Boominator compared to SLAs?and it's going to run on LFP cells instead of SLAs.
I don't think there is any guide, if that is what you are thinking about. You should read this thread, which would probably give you all the information you need, although I know there are a lot of different suggestions and strange numbers to comprehend. If you make one which is roughly the same as Saturnus' original Boominator, then it should last a very long time, both physically and battery wise.
I small to-do list/guide would probably be like this:
1. Look at the pictures of Saturnus' Boominator to get an idea of what it is and will look like. (Two speakers and tweeters on each side, a seperate compartment in the middle for batteries and amplifier. The speakers are glued together magnet-to-magnet to enhance efficiency, and held in place by a piece of wood in the middle of each of the two speaker compartments, but without seperating the compartments, since they should share the volume (I think it's about 23 liters or something). Read and understand parallel and serial connections of the speakers and tweeters.) This is the way we did it, but Saturnus' internal design probably differ somehow.
2. Find it's dimensions in this thread, and get the wood needed to make the box.
3. Find the parts needed. (i.e. amp6-basic, 4x HP-10W speakers, 4x Zomax piezo tweeters, speaker cables, mini-jack cable for mp3-player, 12v SLA battery/batteries, amorphous solar cell that will fit the dimensions of the boominator if built in.) There are other stuff needed too, like volume knob, resistors for tweeter crossover and stuff, but you will find these while reading the thread.
4. Start building! Since there's no guide, you will probably have to do some things your own way, like fitting the solar panel, the batteries etc.
I would probably recommend getting one of the 41hz.com forum users to build the amp and send it to you. We fried ours when testing it, but i think V-Bro build ours perfectly for a small fee.
Hope this helps. You will still have some reading to do in this thread, though
Oh and btw. In a setup like the Boominator, will an Amp9-Basic be significantly louder than the Amp6-Basic? I've tried to understand percieved volume, watts and dB, and as I understand it, the total watt increase from 2x25w to 4x50 will give a boost of 6dB, right? I'ts just hard for mo to understand if 6dB is that much of a difference outdoors like at Roskilde for example.
I guess the 4x amount of power used, will result in less than double the percieved volume(which would be +10dB)?
Hey everybody,
Thanks, Bill
Thanks a bunch mate. And no, I have no problem people copying the boominator or using it as inspiration for their own design.
It's possible you could find something that would equal or be better than the HP10W/GW1058s in price, efficiency, or sound quality but I doubt you can find anything that will equal them in all 3 at once.
There's no piezo I know of that can do what the Zomax HP100 can do but a suitable replacement would be Parts-Express.com: Constant Directivity Horn | super tweeter tweeters tweeter ir horns horn tweeters horn tweeter horn CTS although that would require making a simple filter.
Have you startet on your new boominator saturnus?
Yes Finally.
Glad to hear it
Even more mechanical stability (as if that was really needed), and hopefully a bit better dispersion in the higher mid-range to match the tweeters.
More or less, you'd probably need a set-up trafo to get the gain high enough to match an iPod, if that's your source. Alternatively you could try an integrate a docking station with built in preamp (maybe even remote controlled).
LFPs are half the weight for the same capacity, they can be fully recharged in under one hour, and they last at least 10 times longer (meaning they can be recharged more than 10 times more times before starting to wear) in fact they can probably last 30-50 years in a design like this were you don't recharge that often where SLAs most often don't survive a season intact.
They're also completely safe in every way. Much more so than SLAs or any other kind of battery.
As am I.
And now I have a question for you folks out there. Is there someone who can permanently host a small file, if so then I'll put up the "easy-build"-version Google SketchUp drawing of the original Boominator for all to use.
Doubling the power would actually only give 3dB more. But I'm not actually going to use it in 24V mode. I'm going to use some other tweeters intirely so I need a passive line level filter (PLLXO) with some more ingenious tweaks of my own invention (I think, at least haven't seen it before).
I was more thinking about the fact that Amp9-b has 4 output channels, while Amp6-b has 2. And because of the genius parallel-wiring of the Boominator, it was actually favorable to have only 2 outputs for 4 speakers, so the speakers went from 8ohm to 4ohm. But...
...will this work on the Amp9-b? I understand that it is possible to only use 2 channels of the Amp9, but does that mean that it will become 2x100W instead of 4x50W? If it will only be 2x50W half of the watt will obviously be unavailable to us.
But if we connect a speaker to each channel, it will not be possible to parallel-wire them as we do now, losing the big advantage of 4ohm.
Can you confirm this? Or is there a way to wire it all up in a way that will provide the full total 200W, while keeping the speakers paralleled for 4ohm?
What is the reason you are not using it in 24V mode? That was my original idea to begin with, to get the maximum power for the speakers, resulting in higher volume, right? We have 2x 12V SLA's in our Boominator, so we could just wire them in series to get 24V. I don't suppose this will use more power when at same volume levels as our old 12V solution.
Sorry if these are stupid newbie questions, but I am still a newbie to this
I've just talked to a friend of mine, also involved in our building of our Boominator, and he has a webserver and would be happy to host the file for you. If you could upload it somewhere, he could download it and store it on his server permanetly? If you just give me the link in here.
That would be so awesome
What are your thoughts on this speaker?
TRUVOX-0818MR
They are at 102dB! This would be a huge percieved volume boost from 96dB right?
It is only 8", but 100W RMS as with the HP-10W.
TRUVOX-0818MR
TRUVOX-0818MR
It's a midrange driver. Resonance Frequency at 450 Hz meaning it won't play anything below that.
- Class D
- The Boominator - another stab at the ultimate party machine
