How about doing mentioned klippel test, just to be sure about those percentages?
I will.
Hence the "Absolutely" beginning to my quoted answer.Whatever your expectations are, you should consider them
Right, for example, if someone rubbed Electret Cream on some cables and asked me to listen (and no be so dependent upon common sense and be so close minded, unlike the "hear something", "try everything" crowd), because measurements down to the thermal noise level showed "differences". I would expect to "hear nothing" and proceed to "hear nothing". Now would that be because of my "hear nothing" expectation bias, or because there was "nothing to hear"?if you for example would be convinced that no differences could be audible
Whoa, the last time I heard that term, it was being used in Clark Jonhsen's "Wood Effect", nicely reviewed here as The Witch Effect. You do agree that even if Triple Blind is used to test nothing, nothing will be the result?than you should take a "triple blind" which means, that you will not know what effect will be under test.
I agree.BTW, what i always appreciated in klippels work was their scientific approach; as you might have noticed they did rely for their listening test on studies from people who do routinely test with humans, and this approach is unfortunately quite uncommon in the audio business.
Btw, do you see Klippel recommending to transducer manufacturers that they use thinner silver voice coil windings in their drivers because they sound "better"? Or add series resistance to the drivers using magic wire to improve "details"?
cheers,
AJ
On the same token, is it possible (or probable) that during your sighted, uncontrolled listening, where you "hear something", that there are other factors in play that are not fully realized?I am just stating that there is more than likely other factors in play that are not fully realized.
If one always "likes" the most expensive,the most "recommended" etc....then,yes.But this is not always the case.Many times the brain can be "biased" in favor of our pocket...,or it even has true preferences ???
I believe someone said that repeating the same thing over and over, then expecting different results, was the definition of insanityIf people repeat their results over multiple attempts, whether sighted or not, I just can not attribute this to "bias".
You really ought to read up on "subconscious", to see what conscious control you have over it. Just basic knowledge of human psychology would go a looong way in these threads. Or maybe not .If one always "likes" the most expensive,the most "recommended" etc....then,yes.But this is not always the case.Many times the brain can be "biased" in favor of our pocket...,or it even has true preferences ???
cheers,
AJ
As I said, the truth is most likely in the middle of this argument. ..................
Why do you say that? It is just anecdotal conjecture, not science!
If some believe in the tooth fairy and some not, is the truth likely to be somewhere in between?
No,but if two discuss about it,both have a serious problem
I mean SY could actually send someone else and TG wouldn't know,
Good luck getting someone to bic their head
Just sayin' I think I have seen one picture of SY for 3 secs and can remember what he looks like.
OK. To be consistent then, what about the multiple, "I can't hear any difference" during the blind part of a test?....... If people repeat their results over multiple attempts, whether sighted or not, I just can not attribute this to "bias".
What is this, to bic their head?Good luck getting someone to bic their head ...
Er or maybe I am remembering wrong. I just woke up against my own free will when I wrote that. But isn't SY bald?What is this, to bic their head?
Ah ha! I see now ha ha. Anyway TG wouldn't see anyone until after the test so no need to bicEr or maybe I am remembering wrong. I just woke up against my own free will when I wrote that. But isn't SY bald?
PS I have no idea if Sy is or isn't....... it is what is or isn't inside that counts.
Except for those you guys theorize emanate from cable colours and gold face plates? Body language, tone of voice, and hidden meanings, can't compete with Audioquest Opal.Evidence? The postulation of mind control rays is ludicrous. I've already promised to leave my police whistle at home.
Since there is all of this hoopla over the Klippel testing, I took it and here are my results.Just done the Klippel distortion listening tests. Interesting.
I scored -45db. Pretty pleased - how did you guys go?
Shame they didn't go lower than -45db, that would have really sorted out the men from the boys!
Equipment used: M-audio 2496 soundcard, interconnects of my own manufacture (24ga 5-nines silver in 18ga teflon tubing), Dodd Audio Battery powered Buffer and Stereo Amp, Kimber 8TC speaker cable, Jordan JX92S run full range.
Dave
Well, I didn't say pro amp, its a preamp and loudspeaker processor used in pro audio and a tripath amp. I do have a QSC3500 pro amp as well, not currently in the system. The parts quality of the the Lexicon pre and DBX processor are similar to what would be found in the QSC. Exactly what would cause "skepticism" with my signal chain?
Sorry, don't know what made me think you use pro-amps. As said I don't know any of your equipment.
Huh? Did you catch the part where I posted my scores on an actual "hear differences" listening test? Why would I need to ask those who only claim to be able to hear differences, when I can demonstrate so myself?
I not only know "how to listen", I can demonstrate it. Can you or other believers?
Congratulations, then why do you ask me?
Really? What do soundwaves care about price? How does price affect them?
Is this too cheap Mogami IC, 25 cents (yes, cents)/ft and Mogami speaker wire, $1/ft ?
Are you suggesting that these type wires would in any way degrade or color the playback signal, as to mask "details" and "focus", etc? Especially compared to your cables?
Usually better conductor quality and dielectric material will cost more unless I miss something.
Interesting cables, I like twisted pair cable for IC's, never tried coax cable on speakers, will try it sometime.
Comment? I was hoping you would take the tests . Lord knows we've had enough "comments" in this 11000+ post thread, with nearly zero data or evidence. Vuki has provided the link. I'm sure if you do well, we'll see your scoring. If not, we'll know what happened .
cheers,
AJ
It would be interesting, unfortunately I'm not into computer sound, only got onboard sound (it stopped working about six months ago ) and a set of $1 PC speakers. Will see what I can do.
Dave
Snap. Now ... think you could get -45db with bellwire for cables?
Alan,Snap. Now ... think you could get -45db with bellwire for cables?
I hate to sound smug, but I wouldn't even try. I climbed out of the primordial audio sludge a long time ago.
Dave
- Design & Build
- Parts
- I don't believe cables make a difference, any input?
