JFET choice
Hello all,
I'm working on a new amplifier, a PP one with jfet frontend and Mosfet output stage.
Nothing new under the sun, a good old topology.
The schematic is attached.
I have simulated it with 2SK170 and 2SJ74 jfets, and it simulates very well.
I have now found a good (cheap) source for 2SK246 and 2sj103 jfets.
Do they perform well? From the datasheet it seems they are even better than the ones I used to simulate the circuit.
Is there anybody here that can send me a spice model for 2SK246/2SJ103 jfets?
I searched in anywhere without success.
Please let me know.
Of course, feel free to comment my schematic.
Ciao,
Giovanni
Hi Giovanni,
J-fet models as per your request...I would use 2SK170/2SJ74 cascoded by 2SK246/2SJ103(Erno Borbely style)...and use low Cob transistors instead BD139/140 (like BF472/473 or better)
.model 2SK246 NJF(Beta=1.07m Rs=56.76 Rd=56.76 Betatce=-.5 Lambda=2.8m Vto=-2.638 Vtotc=-2.5m Cgd=10.38p M=.4373 Pb=.3905 Fc=.5 Cgs=6.043p Isr=112.8p Nr=2 Is=11.28p N=1 Xti=3 Alpha=10u Vk=100 Kf=1E-18 Af=1)
.model 2SJ103 PJF(Beta=2.197m Rs=76.76 Rd=76.76 Betatce=-.5 Lambda=735.3u Vto=-2.037 Vtotc=-2.5m Cgd=18.95p M=.5045 Pb=.3905 Fc=.5 Cgs=17.02p Isr=38.48f Nr=2 Is=3.848f N=1 Xti=3 Alpha=10u Vk=100 Kf=1E-18 Af=1)
.model 2SJ74 PJF(Beta=92.12m Rs=7.748 Rd=7.748 Betatce=-.5 Lambda=4.464m Vto=-.5428 Vtotc=-2.5m Cgd=85.67p M=.3246 Pb=.3905 Fc=.5 Cgs=78.27p Isr=129.8p Nr=2 Is=12.98p N=1 Xti=3 Alpha=10u Vk=100 Kf=26.64E-18 Af=1)
.model 2SK170 NJF(Beta=59.86m Rs=4.151 Rd=4.151 Betatce=-.5 Lambda=1.923m Vto=-.5024 Vtotc=-2.5m Cgd=20p M=.3805 Pb=.4746 Fc=.5 Cgs=25.48p Isr=84.77p Nr=2 Is=8.477p N=1 Xti=3 Alpha=10u Vk=100 Kf=111.3E-18 Af=1)
Hello all,
After a few months of stop, I started again my mumbling on the new PP amplifier; the first schematic evolved into something quite complex.
It became a full differential cascode PP amplifier, which perform amazingly well into the simulator (LTSPICE):
Currently I'm in the process of drawing and, then, realize two PCB in manner to try a stereo version of it.
Before I actually build it, is there anything wrong with it?
I mean, it simulates wonderfully but would it work the same in reality?
I'm afraid this beast should be problematic to stabilize, I think it could oscillate badly.
Any issue? Comments?
Attached the schematic, the LTspice simulation file (029.txt: change its extension to .asc) and a zip file containing the needed TL431 simulation data.
Ciao,
Giovanni
  • 029.txt
  • tl431.zip
Hello all,
Ciao,
Giovanni
Hi croccodillo, did this ever materialise??? Were you able to use 2SJ103/2SK246 to replace 2SK170/2SJ74??
