I am starting to source parts for my 1st tube amp project. I am looking to construct Porkchop's KT88 se circuit.
Does anyone know where I can find a suitable 100uF motor run cap? It seems as though no one really carries anything that large in the voltage required. Angela carries 50uF, but I would rather not have to parallel two caps if I can help it.
Are there any other alternatives?
Thanks!
Thanks!
Ebay often has cheap big 'uns. There was one seller in particular, but I can't remember who. These guys have some large fellas as well. Don't forget that you can multiple that AC voltage by 1.4 or so for your purposes.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Paul
midori meadows on eBay used to carry 100uF motor runs, but ran out a while ago, and I have not checked to see whether or not they have restocked.
Edit: Link here to eBay profile: http://myworld.ebay.com/midorimeadowsllc/
Note that she currently is offering 80uF/500VAC motor runs by Eyuda for $13 each...
I've done business with her, and have recommended her as a source of motor runs to a number of friends over the last few years.
Large motor runs are all somewhat inductive, but then so are most electrolytics.
These are probably ok, and at the price it is hard to imagine you could go wrong.
Odd that the seller who is based in Hong Kong listed them on eBay Italia.. Io penso di comprare qualche pezzi di questo condensatore.
Why would you use one of these opposed to a standard 100uf film cap?
experience and sanity are just two reasons I can think of in this moment
Don't forget motor run caps are ac.
huh? A polipropilene cap is a poliprpilene cap anyway
why to use these instead an electrolitic? Give a try, remove your electrolitics from your tube amp and give a chance to these motor run poli caps and hear your music as usually...
- Design & Build
- Parts
- 100uF Motor Run Caps
