ikoflexer said:Very nice, thank you for sharing Anatoliy.
You are welcome!
Triodes loaded on gyrators, source follower loaded on counter-modulated CCS. about 80W of idle power dissipation, 160W for stereo. Minimal load impedance is 8 Ohm, so 16 Ohm high efficiency speakers will be happy. Tower-II dissipated 1.5 KW for 2x200W output power, so this one is a summertime version.
ikoflexer said:Yes, I like the idea of gyrator load. Any first impressions sound wise?
This version exists on a paper only. The previous one I used during 2006 winter. The sound was the best I ever heard, though it worked also instead of a fireplace (1.5 KW dissipation). It caused subconscious reactions of listeners on sounds, I myself once was scared by a running water, other people were scared by a roaring lion. Father in law insisted that it was a real piano playing in our house. And so on.
That means, subconscious mind believed in reality of sounds.
That sounds impressive. Is that in the public domain as well? Wouldn't mind checking out the schematic if it is. This year we've got a very cold summer here, you know
No, Tower-II is not in public domain, but schematic is very similar. I used 8AL9 tube there, but loaded on CCS only instead of gyrators. It uses bipolar power, so DC stability was made by a feedback by DC with direct coupling between stages (through a voltage shift), also an output stage there is a bit more complex, with a degraded emitter follower in parallel with a source follower, and with one more source follower on top for bootstrapping (feed-forward, as well) to linearize in terms of dependence of transconductance and capacitances on drain-source voltage. However, it spends more power, but linearizes additionally without adding of higher order distortions.
Hi Anatoliy
I would .love to have one of those as a kit or ready built, how do I order?
I don’t worry about the heat, its cold here in the wintertime.
BTW: you should have some price and ordering info on your website.
Cheers
S
stinius said:
Hi Anatoliy
I can build one for you really cheap, in my barn, I'll calculate costs and email you.
Anatoliy
Anatoliy
Thanks A
BTW: Maybe I'll need more than 1.
Cheers
S
Wavebourn said:The question is, do you want a full range 2 channel class A 2x200,
or class A 2x100 above 300 Hz plus class A+C 2X200 below 300Hz for woofers?
Is it 240V in your outlet, 6A max?
Are you comfortable with lead containing solder?
Anatoliy
Hi A
I’m looking at full range.
I’ll use another amp on the woofers on one of the sets, but the x-over is about 100Hz.
220V 10A. (If I need more A, no problem)
Lead is no problem.
Cheers
S
Wavebourn said:What about a power supply? Are you comfortable with SMPS, or linear only? The former will generate some fan noise, the later will be very heavy (transformers+chokes).
Your choice?
SMPS is very ok as long as it’s a good one. I hate fan noise.
I can also do the PSU myself, maybe that would be the best?
Cheers
Wavebourn said:It will cost $835 for linear PS (with no fans) parts , $225 for Triad chokes, $450 for toroids, and $160 for capacitors. And, of course, very heavy to ship.
Ok maybe I can get the toroids myself. Less to ship.
You will need 3 toroids with 50-0-50V, 500VA each, and 3 filter reactors Triad C-59U. The rest I will ship assembled, but I will need from you dimensions of your transformers to prepare place for them in the tower.
By the way, do you know Cobra2, Arne? I still keep his tube transformers. He used to have some sneaky way to ship.
Wavebourn said:You will need 3 toroids with 50-0-50V, 500VA each, and 3 filter reactors Triad C-59U. The rest I will ship assembled, but I will need from you dimensions of your transformers to prepare place for them in the tower.
Ok
Email me the details and price, I’ll arrange the transport.
No I don't know Arne (I think).
BTW: He lives in Stavanger, I'm in Bergen, not far away.
Cheers
Dear members of DIY community;
I was not prepared to such popularity of my humble design because "Hybrid" word was spoiled by poor amps with tube stages with high output resistance loaded on class AB complementary follower that could not sound nice, of course.
No kits are available, I have to catch up fast, but please expect at least 2 months lead time. Orders will be completed on FIFO basis.
Anatoliy
Anatoliy
stinius said:
Ok
E-mail sent. Footprint (for Tower-IV) will be 8"x8", 32" high. Transformer balanced XLR ins, banana outs. EM-80 indicators; tubes: 12AX7 X 1 and EL84 x 2.
- Tubes / Valves
- Wavebourn Tower-III High-end hybrid amp
