Some other Source Follower Configurations
I have been thinking about some other configurations than the 3 classics published in Borbely's article JFETS : New Frontiers. I hope I did not re-invent the wheel by accident.
To avoid any trouble with copyright issues, here are the links to figures or circuits referred to in the article :
http://www.borbelyaudio.com/adobe/ae699bor.pdf
http://www.analogzone.com/col_01302004.pdf
http://www.diyaudio.com/forums/head...dphone-amplifier-post1130743.html#post1130743
http://www.diyaudio.com/forums/soli...rch-preamplifier-post1507926.html#post1507926
Taylor Source Follower
http://www.passdiy.com/pdf/zen-ver2.pdf
Enjoy. ;)
Patrick
Someone asked about modifications to the DAO follower as built by Steen.
This is the version with the Taylor Current Source.
The 2SJ103 should have about 8mA Idss.
Depending on JFET Vgs variations, the resistor values might need adjusting. I should start with a 1k trimpot for R1 to set DC offset to zero first.
Hope you'll build this. Total dissipation about 15W.
Patrick
  • dao follower w taylor cs.zip
Hi Patrick,
that's most welcome reading! Thank you very much for your article!
By the way, thank you very much as well for updating your DAO! It's all my fault that another unit wasn't build yet as I waste a lot of time currently with toying with new amp ideas :D
All the best, Hannes
Patrick
Attachment: dao w taylor cs.zip
This has been downloaded 1 time(s).
hehe. Lineup was the first one to download.
I attach the layout in scale 1:1 (almost real size) .. in my 17" monitor
You have unfortunately posted the wrong layout. This is the old layout of the DAO follower without the Taylor CS. The one in the Power Point includes add-on components to turn the old layout into one with Taylor.
I hope you can delete this one to avoid confusion, or at least post the proper one with the 2SJ103 and R1 to R4. I tried to save the Power Point as JPEG but it gave very poor resolution, which was why I zipped instead.
Patrick
The one and only
Joined 2001
Of course if you're dealing with high current, it becomes a virtual necessity.
When you're driving 10K, I've been able to tweak circuits with just two
2SK370's (one as a CCS) and no additional parts down to 0.0004% thd
+ noise at 2 volts. It doesn't leave me with a burning desire for improvement.
:cool:
just used you latest ZIP
if you have the wrong layout in the ZIPPED powerpoint
it is nothing i can do about it .. is there?
Regars
> When you're driving 10K, I've been able to tweak circuits with just two 2SK370's (one as a CCS) and no additional parts down to 0.0004% thd
Agreed. And I did mention the motivation for the alternative circuits in the article -- driving loads (e.g. passive filters) 1k or below.
> if you have the wrong layout in the ZIPPED powerpoint it is nothing i can do about it .. is there?
Just to be sure it wasn't my mistake, I downloaded the zip file from the forum just now, opened it, made it full screen, and printed that into a jpeg (sorry for the poor resolution).
And this is how it should look (see especially bottom left corner) !!!
Nothing wrong with the ZIPPED powerpoint as far as I can tell, probably something with your computer ? Or you are using some Windows Office equivalents ?
Patrick
A brief update on the DAO with Taylor CS.
I have done some more optimisation using measured data from real devices, with the following adjustments to resistors values :
R1 750R (use 1k trimpot to adjust DC offset)
R2 4.7R 3W
R3 4.7R 3W
R4 41R (= 2x 82R //)
The distortion at 2.6V output into 60 ohm load (AKG 701) is compared to the original DAO Follower :
DAO vs w Taylor
Gain 0.926 0.959
2nd -89dB -67dB
3rd -87db -110dB
4th -99db -120dB
5th -121db -143dB
6th -151db -174dB
7th -188db -206dB
One can argue how accurate these values are, but IMHO a general conclusion can still be drawn.
If you want minimum total distortion, then the original DAO is already very very good. And the Taylor brings nothing extra. But if you believe in weighted spectrum. then look at the difference between the two from 3rd order distortion and onwards.
I know which one I would choose, but hope that Steen will give us a subjective comparison before long.
Patrick
