SLN Pre-Amp - Elektor Aug 1982
I want to attempt building this phono pre-amp (see attached schem).
Any tips and ideas on how to possibly improve the circuit?
I am going to configue it for MC cartridges.
Is any one get PCB
Hello everyone !
For fun, I'm trying to make a PCB for this solid-state application but as you can suppose there is few sharpness to catch.
For example, when I want to parallel transistors, I can do it correctly for 2 of the 3 pins of them. :smash:
Common base and emittor are easy
If I want to keep project simple by using only single sided board, to my mind and at this time, I can't . Well for transistors and PCB gurus all around the board, things like could seems trivial so I'm proud to make them laughing. :clown:
So, my question is : Have you got any idea for doing this simply ?
MaxS
PS : I'm working on a part of solution. Thanks in advance.
