Go Back   Home > Forums > Blogs > RJM Audio Blog
If I put my notes here, I might be able to find them again later!
Rate this Entry
Stereo VSPS rev 50c
Posted 25th April 2012 at 12:48 AM by rjm
The original stereo VSPS project is now quite mature. I did a couple of minor tweaks on the last re-spin of the layout, removing the pads for the old Black Gate coupling caps (long gone), adding thermal isolation, and making room for a pair of optional ceramic bypass caps next to the op amp.
The new boards are matt black. Quite cool. I have a small stack if you need any.
All the info you need to build one is attached.
Click image for larger version
ID:	644   Click image for larger version
ID:	645   Click image for larger version
ID:	646   Click image for larger version
Views 2603 Comments 2
Total Comments 2
Comments
  1. Old Comment
    dimkasta's Avatar
    Do you plan any such canges for the 300 as well?
    permalink
    Posted 6th July 2012 at 09:05 AM by dimkasta dimkasta is offline
  2. Old Comment
    rjm's Avatar
    The shipping VSPS 300 have had these improvements for quite some time already (except for the bypass caps, which aren't needed anyway) This is just bringing the older stereo board back up to the current tech level.
    permalink
    Posted 10th July 2012 at 03:27 AM by rjm rjm is offline
Copyright 1999-2017 diyAudio
