Go Back   Home > Forums > Blogs > RJM Audio Blog
If I put my notes here, I might be able to find them again later!
Rate this Entry
The Z-reg
Posted 1st February 2012 at 11:58 PM by rjm
Updated 2nd April 2012 at 02:02 AM by rjm
This is a followup of sorts to the X-reg, though there is nothing original about the circuit this time around.
It's just a Zener voltage regulator with a series pass transistor. I lifted this particular configuration from the Pionner C-21 preamplifier and re-tuned it for op amp applications. My main interest here is trying to make a small and convenient board layout.
I've used this circuit block already in the Sapphire amp and come away impressed.
The output is about 1 V less than the Zener voltage, and the input voltage should be about 3-6 V above the Zener reference voltage. I'm working here with 17 V unregulated supply and 12 V Zeners, but the values can be reconfigured easily enough for any output from 4-24 V
This is a low current circuit. If you are just powering a few op amps, no heatsinks are needed. Above 25 mA small heatsinks are a good idea. The circuit is not designed for output currents above 100 mA.
Click image for larger version
ID:	583   Click image for larger version
Views 1167 Comments 0
Total Comments 0
Comments
Copyright 1999-2017 diyAudio
