If I put my notes here, I might be able to find them again later!
jFET passive phono preamplifier circuit idea
There are various tricks, like parallel input devices and active current sources, that I have avoided here in the interests of simplicity. If you want to go down that road, you can get an idea where it leads, here. Instead, the circuit below is basically a JFET version of my old 6DJ8 amp, here. A single JFET was getting me nowhere in terms of output impedance - around 10kohms! - so I moved to a compound stage buffering each amplifier with a source follower.
Noise and distortion figures look okay. The gain is only 30 dB. A bit low. The main trick is the PSRR, which is awful. The two stage circuit actually amplifies the power supply noise onto the output. So considerable effort must be put into the power supply regulation and filtering. I note that this is pretty much par for the course with this circuit topology where resistors are used instead of current sources on the JFET drains.
The circuit below leaves out the usual RC filter inserted between the power supply and the JFETs. That will be dealt with later, as needed, with the rest of the supply circuit.
Total Comments 0
