If I put my notes here, I might be able to find them again later!
Portable headphone amplifiers
The shift of the center of gravity of the high end from component, rack systems to portable continues. Exhibit A
I've also noticed that over the last couple of years the basic blueprint for a portable headphone amplifier as defined by the Sony PHA-1 has now been taken up by all of the major Japanese audio companies.
Sony PHA-1, PHA-2, PHA-3
Denon DA-10
Onkyo DAC-HA200 and TEAC HA-P50 (variants of the same basic unit)
JVC SU-AX7 (report) (seems to be mostly Kenwood DNA)
Audio Technica AT-PHA100
and Fostex hp-p1
For all the above you are looking at a battery powered, slim-cased DAC + headphone amp typically with some sort of guard around the controls. They all feature a good variety of analog and digital inputs, offer switchable gains, and are priced over a range from $200 to nearly $1000.
You are looking at the convenience of having the DAC built in, the small size, and the rechargeable lithium battery. Its not really an area where DIY can compete, I think its better for home grown efforts to target the full-desktop, all-analog, high-end model where size and power consumption are not important considerations.
Denon DA-10
and Fostex hp-p1
Total Comments 9
Comments
I can't help thinking that portable amps are going to be hamstrung by insufficient power supplies - as you say the size constraint is severe. Have any portable amps taken up using output transformers yet? I have an idea that with a small enough transformer, an amp could use photoflash caps which have the highest energy density of any high voltage caps (excluding supercaps). I rather suspect the trafo won't be particularly portable though.....
Posted 14th January 2015 at 10:14 AM by abraxalito -
Well, there's insufficient in power, which is a rather subjective point, and there's insufficient in voltage, which since I imagine most of these units are regenerating voltage rails using DC-DC converters should not be an insurmountable problem.
As you know, output transformers solve problems and create them. For a push-pull design they wouldn't have to be all that large, but perhaps "portable" is still a bit of a stretch.Posted 14th January 2015 at 11:53 AM by rjm -
I have some reasonably compact ferrite trafos in my transportable Ozone DAC. For driving low impedances from opamps they're invaluable but they're at least 20mm tall so wouldn't fit into a low profile case. However I still need a much bigger volume of caps to get the best dynamics, so caps are the primary problem. Perhaps pure classA is a better solution though. When I said 'insufficient' I meant insufficiently low impedance - i.e. too saggy.
Posted 15th January 2015 at 12:23 AM by abraxalito -
Posted 15th January 2015 at 12:31 AM by rjm -
I guess mine are parafeed, I just put them between the driver (normally a CFB high-drive opamp like AD8017) and the transducer, fed through an LC low-pass filter and a 'lytic to block DC. I like to run the driver IC as close to its max supply as possible, so around 10V for the AD8017. I reckon though that higher voltages will probably sound better, because that necessitates a bigger step-down ratio and hence attenuates PSU noise more. Forgot to mention - given the AD8017 is a dual, I run them anti-phase, i.e. the trafo is driven as BTL, doubling the swing.
Posted 15th January 2015 at 02:01 AM by abraxalito
Updated 15th January 2015 at 02:15 AM by abraxalito -
Posted 15th January 2015 at 06:34 AM by rjm -
Posted 15th January 2015 at 03:34 PM by abraxalito -
Posted 15th January 2015 at 11:23 PM by rjm -
Yes, I wasn't meaning 20dB less noise, rather that much reduction of PSU-induced noise. PSU noise is signal dependent and I reckon its in the main introduced by the output stage. Yes partly I was inspired to try this from learning about how dynamic McIntosh amps sound with their autoformer outputs. I was shocked how dynamic my old Sony headphones (CD3000) sounded once fed via a trafo - previously I'd figured that the fatiguing sound at higher levels was due to their age. The trafo's given them a new lease of life.
Posted 15th January 2015 at 11:50 PM by abraxalito
