Go Back   Home > Forums > Blogs > RJM Audio Blog
If I put my notes here, I might be able to find them again later!
Rate this Entry
Gemini Amp - and an idea for yet another headphone amp output stage
Posted 25th April 2014 at 10:13 PM by rjm
Updated 26th April 2014 at 07:19 AM by rjm
As a companion post to the GeminiPS I thought I'd throw the amplifier circuit out there too...
It's not something you'd have any reason to built today I think, but some of the ideas are worth revisiting.
The output stage is what is normally referred to as a complimentary Sziklai pair. The LTSpice circuit below uses the same output, but with the diamond buffer type bias, with it all scaled down to headphone-amplifier voltages and loads. It would be interesting to compare it against i.e. the conventional diamond buffer used in the Sapphire headphone amp. Maybe I'll get around to it. The simulation shows a bit more transient peaking than the straight diamond buffer, ideally there could be some way of adding compensation / reducing the bandwidth to more reasonable levels.
Click image for larger version
ID:	1277   Click image for larger version
ID:	1278   Click image for larger version
ID:	1279   Click image for larger version
ID:	1280   Click image for larger version
Posted in The Lab
Views 1314 Comments 0
Total Comments 0
Comments
Copyright 1999-2017 diyAudio
