Go Back   Home > Forums > Blogs > RJM Audio Blog
If I put my notes here, I might be able to find them again later!
Rate this Entry
J-Mo Mk. II vs. Szekeres, distortion comparison
Posted 3rd May 2013 at 08:24 AM by rjm
Updated 5th May 2013 at 11:52 PM by rjm
Two headphone amplifiers sharing the same basic MOSFET source follower output stage.
When the source current and source resistance are optimized for the given headphone load and similar maximum output power (~50 mW at 1% THD), the distortion pattern vs. output power is remarkably similar.
One plot below is simulation, the other measurements. The J-Mo 2 simulation closely matched the actual measurements, it wasn't worth my while to generate a full simulated data set when I already had the measurements on hand. No reason to suspect that the Szekeres sim is inaccurate, either.
The take home message is the distortion characteristic of a MOSFET follower is what it is, and unavoidable. Take it or leave it, as it were. However - and this is key - if you don't optimize the stage for the headphone impedance, the distortion for a given output power will increase significantly.
As an aside: Greg did his homework with the original circuit. It's very nicely optimized for the 30 ohm Grado SR60 headphones it was designed to drive.
Click image for larger version
Name:	szekeres THD sim.png
ID:	980   Click image for larger version
Name:	jmo2 thd sim.png
ID:	981   Click image for larger version
ID:	982   Click image for larger version
Views 1201 Comments 0
Total Comments 0
Comments
Copyright 1999-2017 diyAudio
