Go Back   Home > Forums > Blogs
Old
Wide-band RF mains filtering - part II
Posted 14th February 2011 at 05:24 AM by abraxalito
Updated 2nd March 2011 at 12:10 PM by abraxalito
I've been actively researching via Google on this project since the last posting and found out a few interesting things which I'll share here.
Firstly I checked out piano wire as the material for making the L1 & L2 input side chokes in my original schematic. I couldn't find any consistent figure for what the permeability of piano wire is - it seems steel comes in so many variants that its hard to tell. So I continued to look for alternative materials which have reasonably high permeability. Remember, its the high permeability which gives rise to skinny skin depths and hence higher losses as the frequency climbs. Normally this is really undesirable, but for our purposes its exactly what we're looking for.
Other elements which have high permeability include nickel, cobalt and iron. Nickel wire is available, but its expensive and not widely sourced. Cobalt is even more expensive with even fewer sources. Iron is the cheapest option and it turns out that iron...
abraxalito's Avatar
Posted in Mains filtering
Views 1072 Comments 0 abraxalito is offline
Old
speaker enclosure calculations
Posted 12th February 2011 at 08:17 PM by seniordesign
Hello,
I am currently constructing a sealed enclosure for a 12 inch woofer with a resonant frequency of 38 Hz.
My senior design mentor wants me to alter the resonant frequency of the speaker by using a smaller enclosure to shift the frequency at which it resonates to 100 Hz. Its is being used in an interferometer, not for playing music, so I do not need to worry about sound quality.
Does anyone know of the calculations used to alter the Fs?
Thanks!
Posted in Uncategorized
Views 1919 Comments 1 seniordesign is offline
Old
Dynaudio PPM2 Loudspeakers
Posted 11th February 2011 at 05:36 AM by simpsonjp
I just bought a set of Dynaudio PPM2 monitors on auction at Audiogon. Does anyone know where to get any data on these speakers (ie spec sheet or reviews). Anyone own a set or have heard them?
Thanks,
Jeff
simpsonjp's Avatar
Views 1463 Comments 0 simpsonjp is offline
Old
PC Crossovers
Posted 10th February 2011 at 08:36 PM by DougL
This looked Interesting.
http://www.diyaudio.com/forums/multi...ml#post1033586
I'll have to research that.
Views 1684 Comments 3 DougL is offline
Old
Digitally controlled class D
Posted 8th February 2011 at 08:24 PM by alexcp (My DIY projects)
Updated 17th December 2011 at 02:24 PM by alexcp
I wanted to build a Class D amp based on TI's PurePath chips - e.g. TAS5086 PWM processor and a few TAS5162 power stages - until I read Bruno Putzeys' "The Truth About Digital (Class D) Amplifiers". He makes a convincing argument that digitally controlled class D is a dead end street. I also noticed that very few people around here have been writing about PurePath. Shall I look at the UcD patent and application note, as well as ready made Hypex modules, instead?
alexcp's Avatar
Views 1513 Comments 0 alexcp is offline
Old
Wide-band RF filtering for mains
Posted 5th February 2011 at 05:07 AM by abraxalito
Since Ostripper asked about mains filtration on the RF & Audio thread, here are some notes and ideas. I haven't built any of this yet - if you decide to, I'll be interested in any results - photos and listening reports. Be careful with this stuff, its at mains potential.
Pre-built mains filters are of some use in audio, but they're not really optimised for high-end sound. For audio source components, the draw is normally under 100W and so the current (assuming here 230V supply) is under half an amp. Few if any off the shelf mains filters are designed for such low currents.
Second, the commercial filters assume that we wish to stop conducted interference getting out as much as prevent muck getting in. The internal noise would normally only come from the rectifiers in a linear power supply (SMPSUs are a totally different matter). Once we've snubbed them (you have done that already right, or are using soft-recovery or schottky diodes?), with a linear...
Click image for larger version
ID:	324   Click image for larger version
abraxalito's Avatar
Views 3623 Comments 3 abraxalito is offline
Old
service manual NAD 7225 pe
Posted 1st February 2011 at 10:01 PM by migouel
Hi all. I have a NAD 7225 PE Amp that seems to not power up. Does anyone have a service manual for it or schematic? Where can I find info to help me fix the tuner? 4 Fuses Blown,Display,FM scan works ok.
Views 2191 Comments 1 migouel is offline
Old
My "Salas hotrodded DCB1" build
Posted 27th January 2011 at 08:06 AM by Rodeodave
I built the 10R version for now, maybe I'll up the current later. The power resistors I used are non-inductive planar 10R 5w thick film resistors (BI Technologies BPC5100J). The noise figures are comparable with metal film it seems. I just thought I'd give these a try, and since I'm using many fancy flavoured parts (at least for my taste) it fits the bill. I had to remove the original legs, which were some clamp-on soldered types, and fit them with bent copper leads since the original spacing was too small for the board. If you look close enough you can see it in the second picture.
The MOSFETs are IRFP140N/9140N. The 5-LED chain is matched to 9.30V/9.29V (values measured in circuit), using 12VDC and 1k in series with it. The 3-LED chain was matched to 5.59V/5.58V (measured in circuit). The 5-LED chains are fed by 2SK170 that I once measured to...
ID:	316   Click image for larger version
ID:	317   Click image for larger version
ID:	318   Click image for larger version
ID:	319   Click image for larger version
Rodeodave's Avatar
Views 4804 Comments 0 Rodeodave is offline
Old
MR211's Blog
Posted 25th January 2011 at 07:23 AM by asterkao
Updated 3rd September 2013 at 01:22 AM by asterkao
http://kao211.blogspot.tw/
asterkao's Avatar
Views 1204 Comments 0 asterkao is offline
Old
Compact PCB For All JFET Circlotron
Posted 25th January 2011 at 12:59 AM by Michael Rothacher (Audiohobby.com)
Updated 2nd October 2011 at 11:59 AM by Michael Rothacher
This is the artwork for the PCB in the pictures. It fits into the ExpressPCB miniboard profile so it's a little cheaper to have made.
It will be necessary to check the orientation of the bias pots (I can't remember). I wouldn't want you to blow-up your $30 JFETs.
Michael Rothacher's Avatar
Views 3513 Comments 5 Michael Rothacher is offline
Copyright 1999-2017 diyAudio
