Go Back   Home > Forums > Blogs
Old
one small step...
Posted 8th January 2012 at 01:58 AM by cberger
... for mankind, but one giant step for me
After sucking big time in Halo, In felt like I needed some positive experience today, so I hooked up my CHR-70s to my trusted, semi-retired NAD.
Took about 1h, involving looking for my cutter to cut some old CAT5 and strip the wires, do the actual cutting and stripping, hooking up the receiver, connecting the cables and turning on the whole assembly.
And *drum roll* FM94.9 played Motorhead's "Ace Of Spades" Can it get any better???
First listening impression: sounded a bit like AM radio, but given the way the drivers are hooked up I'm not really surprised...
in other news: parts express delivered some fluff and my terminals
Click image for larger version
ID:	557   Click image for larger version
ID:	558   Click image for larger version
Posted in Mk3
Views 414 Comments 0 cberger is offline
Old
SouthSemi modified F2J Clone
Posted 7th January 2012 at 10:13 AM by Tea-Bag
Updated 21st November 2010 at 01:46 PM by Tea-Bag
This last weekend I replaced the IRFP240 in my F2 Clone with the R100 SouthSemi Power-JFET.
tubes-guy used psychic powers to control my mind and force me to do it.
The bias dropped off the bat. I re-biased and gave it an A-B listen to the standard channel. Seemed to be a bit 'cleaner' sounding the the default channel.
Nelson has recommended the following changes to the circuit, which I hope to implement soon. I will be re-wiring these on Peter Daniels boards.
The Peter Daniel boards are still available I believe.
http://www.diyaudio.com/forums/group...group-buy.html
Papa sayz...
The F2's that I have updated with the JFETs need the
following changes:
R6 = 47k (changed to 8.2K of FW Site)
C1 = 10 uF
Z1 removed
The potentiometer must be re-adjusted for minimum
distortion at 4.5 watts (symmetric clipping) and readjusted
Tea-Bag's Avatar
Posted in Uncategorized
Views 4029 Comments 2 Tea-Bag is offline
Old
Progress so far
Posted 6th January 2012 at 01:02 PM by rjm (RJM Audio Blog)
Updated 7th January 2012 at 03:00 AM by rjm
The first stage is getting the power supply installed and running. That's the little board by the transformer, which just has the diodes, main filter capacitors, and isolation resistors on the voltage rails. The case top lid is transparent plexiglass, so the internals are lit by three white LEDs to show off, and light the control labels, which are printed on the top lid rather than the front and back sides of the case.
You'll notice I have followed the instructions and removed the plastic covers on the electrolytic capacitors.
For the record I do think they sound better that way, I just normally can't be bothered as, for example, my phonoclone 3 boards have 28 of them and I consider the exposed metal surfaces a bit of a safety issue as well.
rjm's Avatar
rjm
Views 968 Comments 2 rjm is offline
Old
47 Labs 0247 unboxing, part deux
Posted 5th January 2012 at 11:29 AM by rjm (RJM Audio Blog)
My kit was missing the amplifier circuit boards! So many other neat stuff distracted me from this vital fact!
So far I've wired the AC power line components, transformer, and the power supply board. It's slow progress, mainly for wanting to be sure of getting it right the first time. It's dense and fiddly, desoldering stuff in there to fix a ****-up would not be pleasant work at all.
rjm's Avatar
rjm
Views 861 Comments 0 rjm is offline
Old
Five-times-bandwidth
Posted 3rd January 2012 at 05:44 PM by rjm (RJM Audio Blog)
If we accept that conventional wisdom that the audio bandwidth extends from 20 Hz to 20 kHz, a good rule of thumb for the f(-3 dB) high and low cutoff points of the frequency response of each audio circuit element is 5x the bandwidth, or 4 Hz to 100 kHz. In practice most designs tend to shift that range a little to the higher frequencies, so perhaps 5 Hz - 200 kHz, or 4 - 250 kHz.
Personally I "tune" my circuits to 4 Hz. That is, the time constants are adjusted to about 4 ms. Capacitance is usually cheap enough to go even longer, but the influence on sonics is typically net negative.
The high frequency side is more interesting, since many circuit elements naturally run into the megahertz range, the the question is do you actively try to prevent that, and if so, where and how?
The biggest issue is bypassing: a small value electrolytic (100 uF) is probably fine up to 100 kHz or so, but quite useless at 2 Mhz. The textbook solution is...
rjm's Avatar
rjm
Views 741 Comments 0 rjm is offline
Old
How much power is enough for an amp?
Posted 2nd January 2012 at 03:09 AM by alexcp (My DIY projects)
Bruno Putzeys posted:
About power ratings, well... Normal "critical listening" levels hover around a long-term average of 85db SPL at the listening position. If we're assuming uncorrelated signals (rather inaccurate assumption but it'll do for the purpose) that is 82dB SPL for each speaker alone. Crudely calculating back from a 2m listening distance to the 1m standard measuring distance that's 88dBSPL, one speaker, one meter. It's not unusual for speakers to have an efficiency of 88dB/1w/1m so 1W is roughly the required amplifier power.
The current crop of unlistenable hypersquashed pop music has a peak to average range of around 4dB. So all it takes to reproduce pop at a reasonable level without clipping is a 4dBW (2.5W) rated amp.
Before the loudness war got into swing (say until the early 90's) peak-to-average ranges up to 14dB could be found in mainstream music. To play Sultans of Swing at the same average level requires an amp rated at 14dBW
alexcp's Avatar
Posted in Speakers
Views 1533 Comments 0 alexcp is offline
Old
Improved current source
Posted 2nd January 2012 at 01:18 AM by klewis
http://www.diyaudio.com/forums/solid...urce-sink.html
klewis's Avatar
Views 890 Comments 0 klewis is offline
Old
Solid state relay
Posted 30th December 2011 at 11:55 PM by klewis
Updated 3rd January 2012 at 03:43 PM by klewis
Fets: http://www.diyaudio.com/forums/solid...relays-17.html
Pavel's Scheme http://www.diyaudio.com/forums/solid...ml#post2835407
Also see post #340, increase R1 to 100k and C3&4 to 47uf
recommendation for mosfets: #314
In general, you are seeking for a MOSFET with very high Vdsmax, very low Rdson and very high Idmax. Regarding Vdsmax, it must be higher than the sum of positive and negative supply rail voltage, and the output should be provided by clamping diodes connected to supply rails, reverse polarized. My tips are
Type Vdsmax Rdson Idmax
IRFB1227 200V 0.0197ohm 130A
IRFP90N20D 200V 0.023ohm 94A
IRF3710ZG 100V 0.018ohm 59A (too low Vdsmax to me)
IRFS59N10D 100V 0.025ohm 59A (too low Vdsmax to me)
klewis's Avatar
Views 1291 Comments 0 klewis is offline
Old
Mk3: How to do this...???
Posted 30th December 2011 at 09:45 PM by cberger
Updated 30th December 2011 at 09:47 PM by cberger
hmmm...the plan calls for 5 degree angles for some cuts. How to do those? Just sand it away?
Posted in Mk3
Views 485 Comments 0 cberger is offline
Old
it's xmas time
Posted 30th December 2011 at 09:30 PM by cberger
Updated 30th December 2011 at 09:48 PM by cberger
So I finally decided to build my first set of speakers: The Frugel-Horn mk3.
Reasons:
  1. Fairly high WAF
  2. Looks good (see point 1)
  3. Can be built with "cheap" components
  4. Reasonably challenging wood work
  5. full range driver = no crossover needed
Most of the stuff I ordered so far I ordered based on recommendations / suggestions from the people here like Planet10 Dave, ChrisB and others.
Some stuff that I ordered on Monday arrived already :-)
2 CHR-70 Drivers
CSS UltraTouch insulation
Just now I ordered some terminals, a circle jig (jasper #400), and Acousta stuff
Posted in Mk3
Views 390 Comments 0 cberger is offline
Copyright 1999-2017 diyAudio
