Go Back   Home > Forums > Blogs
Old
Amp Camp Amp Build Instructions
Posted 8th October 2012 at 06:10 PM by N Brock
Updated 26th October 2012 at 07:36 PM by N Brock (added link)
http://www.diyaudio.com/forums/diyau...ild-guide.html
Here is the link for the actual build guide.
Click image for larger version
Name:	1 full kit.JPG
ID:	753   Click image for larger version
Name:	2 board list.JPG
ID:	754   Click image for larger version
Name:	3 R strip.JPG
ID:	755   Click image for larger version
Name:	4 R bend.JPG
ID:	756   Click image for larger version
Name:	5 R insert.JPG
Name:	6 R clip.JPG
ID:	758   Click image for larger version
Name:	7 multi R.JPG
ID:	759   Click image for larger version
Name:	8 all R.JPG
ID:	760   Click image for larger version
Name:	9 power R.JPG
ID:	761   Click image for larger version
N Brock's Avatar
Posted in Uncategorized
Views 2018 Comments 0 N Brock is offline
Old
fs2
Posted 8th October 2012 at 06:09 PM by N Brock
fs2
Name:	11 close.JPG
ID:	763   Click image for larger version
Name:	12 ZTX450.JPG
ID:	764   Click image for larger version
Name:	13 LSK170.JPG
ID:	765   Click image for larger version
Name:	14 all but C1.JPG
ID:	766   Click image for larger version
Name:	15 complete board.JPG
Name:	16 xtr hardware.JPG
ID:	768   Click image for larger version
Name:	17 xtr bend.JPG
ID:	769   Click image for larger version
Name:	18 micas.JPG
ID:	770   Click image for larger version
Name:	19 apply grease.JPG
ID:	771   Click image for larger version
Name:	20 place mica.JPG
N Brock's Avatar
Views 787 Comments 0 N Brock is offline
Old
fs3
fs3
Name:	21 place xtrs.JPG
ID:	773   Click image for larger version
Name:	22 under washer.JPG
ID:	774   Click image for larger version
Name:	23 bolted down.JPG
ID:	775   Click image for larger version
Name:	24 in wires.JPG
ID:	776   Click image for larger version
Name:	25 in soldered.JPG
Name:	26 out soldered.JPG
ID:	778   Click image for larger version
Name:	27 LED done.JPG
ID:	779   Click image for larger version
Name:	28 power.JPG
ID:	780   Click image for larger version
Name:	29 power deet 1.JPG
ID:	781   Click image for larger version
Name:	30 power deet 2.JPG
N Brock's Avatar
Views 703 Comments 0 N Brock is offline
Old
fs4
Posted 8th October 2012 at 06:07 PM by N Brock
fs4
Name:	31 power deet 3.JPG
ID:	783   Click image for larger version
Name:	32 testing.JPG
ID:	784   Click image for larger version
Name:	33 Enjoy.JPG
N Brock's Avatar
Views 512 Comments 0 N Brock is offline
Old
Tube amp progress
Posted 21st September 2012 at 03:19 AM by wlowes
In the past few weeks I have made progress on by OTL amps. The wooden bases are finished, and I am very happy with the finish.
I reformed and tested all the big can caps. The Nippon Chemi Caps are fine. The big old Samgmo caps make me too nervous to consider using them. They may be serviceable, but have a high leakage current compared to the Nippons and do not seem to hold a charge. Perhaps I'll use them in some other project. I will buy 2 x 2200 caps for each rail. 4 per mono and 8 in total. This caused yet another redesign of the top plate. I have now got room to place a big heat sink on top. It will disipate heat from bridge rectifiers and big resistors used for soft start.
Finally I started to build. While all point to point wired, the amps will be modular. I am using wood blocks as the base for each power supply circuit. I laid out the supply for the small tube anodes and wired them up. This way the caps are well supported and vibration damped....
Name:	Small tube anode power modules - building.jpg
ID:	743   Click image for larger version
Name:	Small tube anode power modules - scale.jpg
wlowes's Avatar
Views 935 Comments 0 wlowes is offline
Old
My 6c33c OTL project
Posted 21st September 2012 at 03:03 AM by wlowes
I am starting this blog to create a record of my first tube amp project. The project is to build a pair of 110W 6c33c OTL monoblocks based on Bruce Rosenblit's patent. I am starting the blog at the stage that I am well into the project. I started planning and collecting parts well over a year ago and am at the stage where execution is under way.
So how did I end up with this choice? My DIY audio experience got under way with a Peter Daniel chip amp which I enjoy to this day. Along the way I discovered the Lampizator site leading to the creation of a 1541A DAC with 6np2 tube output. When this sprang to life I was hooked on the idea of building a tube amp. I have never actually heard a tube amp. The look is very fundamental. I want to experience the additional nuances in the music reported by tube amp fans.
I wanted to start with something simple but good quality for my first project. I also wanted to keep costs in check. I figured that good quality...
Name:	6c33c walnut base 1.jpg
ID:	740   Click image for larger version
Name:	6c33c walnut base 2.jpg
ID:	741   Click image for larger version
Name:	6c33c walnut base construction.jpg
wlowes's Avatar
Views 3221 Comments 1 wlowes is offline
Old
Akihabara, lost to the maids.
Posted 20th September 2012 at 11:51 PM by rjm (RJM Audio Blog)
Updated 23rd September 2012 at 11:24 PM by rjm
A maid cafe is, as far as I can make out - and wikipedia confirms - a cafe/light restaurant staffed by girls who dress up as anime characters or doll-like maid costumes. Chatting with customers is encouraged, so the atmosphere is more social than a regular cafe. Its also more expensive, and the food worse. (from what I can judge from the menus: its what my nine year old daughter might make if left alone in the kitchen...) They advertise by by having the staff stand around - in costume - on busy street corners nearby handing out small cards.
This is a phenomena that started about 5-6 years ago, or at least started to go mainstream then. Ground zero for maid cafes is the "nerd districts" where computers, comic books, and video games were sold: Akihabara in Tokyo, Nipponbashi in Osaka.
Growth appears to be exponential: every time I visit either region (I'm in Tokyo right now, staying near Akihabara) the number of maid cafes (and therefore maids on the street)...
rjm's Avatar
rjm
Views 1519 Comments 3 rjm is offline
Old
Finally packaged up "new" ADAU1442 DSP
Posted 2nd September 2012 at 08:11 AM by googlyone
Updated 15th September 2012 at 08:10 AM by googlyone
Wow - it has taken me months to finally get around to packaging up my latest DSP. With work, travel and holidays I have a huge bag of excuses, but I guess the actual reason is that my old DSP using the Analog Devices AD1940 actually works just fine.
The results are I think pretty neat:
The case was made from leftover bits from the last set I built - the sides are simply timber with a groove routed for the top and bottom panels to sit in, and the front and rear panels screw into the timber sides. It makes a change from the multitude of "all metal" cases that litter my workroom and playroom.
The implementation here has one analogue to digital converter and four digital to analogue converter cards.
These can be seen here:
Where the ADC is the first vertically mounted bard on the left with the slightly scruffy IDC cable. The four DACS...
Views 2067 Comments 1 googlyone is offline
Old
NXP's innovation in smart phone sound - any implication for the high-end?
Posted 2nd August 2012 at 05:13 AM by abraxalito
EET seems to be on a run of interesting articles of late - and here's the latest, about NXP's latest digital amp for smartphone speakers:
Achieving loud, rich sound from micro speakers
So yeah, smartphones are a long way from the high-end you say, so why talk about this at all? Well one sentence at the end caused me to pause and wonder how long before this kind of technology gets used where sound quality (rather than quantity) is paramount. I quote:
This leap in performance illustrates an important design trend. The days of stand-alone amplifiers and converters designed in isolation have gone.
The writer has put his finger on a major reason why the high-end of audio is a relatively stagnant pool for innovation. Pretty much everything's designed in isolation - players, amps, speakers. What if those days really are coming to an end, not just in smartphones but in quality audio too? Smartphones have the volume so there's economic...
abraxalito's Avatar
Views 1880 Comments 7 abraxalito is offline
Old
Cirrus now Apple's poodle
Posted 1st August 2012 at 04:53 AM by abraxalito
Cirrus (familiar to us in the audio world as a major ADC/DAC and codec supplier, formerly Crystal Semiconductor) has engineered itself into a tight corner by having over half its sales come from Apple - but its not permitted to mention its largest customer by name due to Apple's draconian NDA.
I wouldn't say things are looking very bright for Cirrus - to be that dependent on one single customer who is that much more powerful than you and a known corporate bully strikes me as poor strategic thinking.
Apple captive Cirrus gagged
abraxalito's Avatar
Views 1089 Comments 2 abraxalito is offline
Copyright 1999-2017 diyAudio
