Go Back   Home > Forums > Blogs
Old
Preamps are not line level.
Posted 1st April 2013 at 04:57 AM by rjm (RJM Audio Blog)
If you don't think about it too hard, you'd imagine that the signals in the phono stage would be smaller than the signals in the line level preamplifier stage that follows it. Or that the signals in the DAC/CD player would be about the same level or slightly lower than the signal in the preamplifier.
As usual, the answer is "it depends". It depends on the sensitivity of your speakers, how loud you are listening, and the voltage gain of the amplifier. It also depends on whether we are talking about a MM phono stage or low output MC.
My point is simply this: the volume control is an attenuator, and at the typical "9 o'clock" position the input signal is reduced in magnitude by about 35 dB.
That cuts it back down to being comparable to the output of a moving magnet cart, and much, much smaller than anything found in a DAC stage.
It means you absolutely, definitely, positively must spend as much effort and care...
rjm's Avatar
rjm
Posted in The Lab
Views 830 Comments 4 rjm is offline
Old
FM tuner for Jitter analysis
Posted 29th March 2013 at 03:34 PM by 1audio
A few quick notes on using a tuner for digital audio clock jitter analysis (before I forget the details). Someone here (I have forgotten who) suggested an FM tuner for monitoring jitter. After a little research and experimentation I went pretty deep into figuring this out.
First the internal clocks on ADC's and DAC's have strong harmonics into the FM band. Second, FM tuners are very sensitive to modulation to carriers. modulation and jitter are closely related. The other advantage of this is that the jitter/phase noise is multiplied by the ratio of the actual carrier and the harmonic you are looking at. E.g. a 22.5792 MHz clock becomes 90.3168 MHz with the noise amplified by a factor of 4.
This is very simplified but covers the essentials-You need a really low noise FM tuner. Sound good is not an issue. The Yamaha TX-930 and TX-950 are possibly the lowest noise tuners ever made. They can be had for around $100 on eBay. What I did was to take the output directly...
Posted in Uncategorized
Views 1725 Comments 1 1audio is offline
Old
Red Baron V4.0 - 3.3V I2S attenuator modification
Posted 29th March 2013 at 01:15 PM by dvb projekt
Updated 30th November 2016 at 09:10 AM by dvb projekt
dvb projekt's Avatar
Views 1874 Comments 0 dvb projekt is offline
Old
Red Baron V4.0 free running DEM oscillator modification
Posted 29th March 2013 at 12:02 PM by dvb projekt
Updated 30th November 2016 at 09:11 AM by dvb projekt
Views 1569 Comments 0 dvb projekt is offline
Old
Personal announcement
Posted 26th March 2013 at 05:24 PM by dvb projekt
Updated 26th March 2013 at 05:27 PM by dvb projekt
Well my friends it is time again to say thanks to all of you, who like and ordered my pcbs.
Because i am no developer of electronic circuits but have the knowledge to design pcbs,
i wanted to give something back to the community.
Since i started with my 1st pcb, the Optical-Volume-Control on 15th October 2009,
a small donation from every sold pcb goes to diyaudio.com
Today i am proud to say that your cumulated donation achieve
$ 3104
Keep on having fun with my pcbs and best regards
Oliver
Views 1094 Comments 4 dvb projekt is offline
Old
Rating: 2 votes, 5.00 average.
Tube-I-zator / TDA1541A recommended modification #2
Posted 24th March 2013 at 02:10 PM by dvb projekt
Updated 30th November 2016 at 09:13 AM by dvb projekt
Views 1563 Comments 1 dvb projekt is offline
Old
I didn't even know this site offered blogs...
Posted 21st March 2013 at 05:28 AM by Midnightmayhem
I did not know that you could do this until just now so bear with me. I intend to make this a main outlet for the cool stuff I build.
Views 660 Comments 0 Midnightmayhem is offline
Old
Tube-I-zator V2.0 / TDA1541A recommended modification
Posted 20th March 2013 at 10:11 PM by dvb projekt
Updated 30th November 2016 at 09:14 AM by dvb projekt (Resistor type added)
Views 916 Comments 0 dvb projekt is offline
Old
Active elliptic anti-imaging filter
Posted 20th March 2013 at 03:18 AM by abraxalito
Updated 20th March 2013 at 03:30 AM by abraxalito (Added FR)
Passive filters rock for SQ, no doubt about it but I'm still curious how good sounding an active DAC I/V post filter might be. So I've figured out an almost equivalent FR active version of my 7th order LC elliptic filter. This active elliptic has been designed using LTSpice's FilterCad program giving the pole/zero positions, then the Williams handbook of filter design helped me translate those numbers into a working circuit. Its using what Williams calls the VCVS 2nd order section based on a twin-T network to realize the zeroes.
My first attempt at an active elliptic filter was using gyrators but that proved very hard (practically impossible) to get stable with CFB opamps due to their HF gain peaking. VFB opamps I ruled out at the start for inadequate SQ - its not hard to make gyrators stable with them. Hence this approach which promises to work with CFBs though I'd guess I'll probably need to add series Rs between the stages in practice. Nothing built yet but thought I'd...
Click image for larger version
ID:	922   Click image for larger version
abraxalito's Avatar
Views 1914 Comments 12 abraxalito is offline
Old
Marantz SR2285B Receiver : Phono Stage Model Response
Posted 19th March 2013 at 06:02 AM by rjm (RJM Audio Blog)
Updated 20th March 2013 at 01:54 AM by rjm
Mid-range 1970's stereo receiver.
I was curious to find out a) what the phono circuit was, and b) how tight the RIAA response might have been.
The answer is "four transistors" and "pretty damn good", respectively.
We are impressed. These Japanese engineers knew a thing or two. I would like to see some of these old circuits resurrected as discrete phono stages with modern components to see just what they are capable of.
Name:	Marantz SR2285B phono.png
ID:	917   Click image for larger version
Name:	Marantz SR2285B ps.png
ID:	918   Click image for larger version
Name:	Marantz SR2285B sim2.png
ID:	919   Click image for larger version
Name:	simluated results.png
rjm's Avatar
rjm
Posted in The Lab
Views 2428 Comments 2 rjm is offline
Copyright 1999-2017 diyAudio
