Go Back   Home > Forums > Blogs
Old
Choosing a USB DAC
Posted 26th September 2015 at 11:49 AM by rjm (RJM Audio Blog)
Updated 9th October 2015 at 04:24 AM by rjm
My Onkyo soundcard drivers stopped working when I upgraded to Windows 10. Onkyo says they have no plans to release a patch, so I'm left with no high quality audio solution for my computer. Since I already have a good headphone amplifier, what I'm mainly looking for is a high quality line level analog output.
One options is another soundcard, the ASUS Xonar STX being the obvious choice. I dunno, it doesn't grab me.
I was thinking with going with an external box this time, connected via USB. As this opens up about a zillion options, I'm going to limit things to,
  1. Respected audio brands with a solid reputation for digital audio.
  2. Small enough to be placed on top of my computer case.
  3. $500-ish, used or new.
My short list includes the following: Denon DA-300usb, TEAC UD-301, and Onkyo DA-1000. Teac also makes the 301's big brother, the UD-501. This is a much nicer unit, very substantial. A bit large. Rounding out the field is the LUXMAN DA-100 . These can be found deeply...
Click image for larger version
ID:	1727   Click image for larger version
ID:	1728   Click image for larger version
ID:	1729   Click image for larger version
rjm's Avatar
rjm
Views 2569 Comments 5 rjm is offline
Old
Rating: 2 votes, 4.50 average.
Discrete transistor based CFB I/V stage
Posted 25th September 2015 at 01:56 PM by abraxalito
Updated 26th September 2015 at 01:35 AM by abraxalito
Since I figured out the reason for needing all those caps in my earlier DAC designs was all brought on by using passive I/V, I'm now a total convert of active I/V in order to do away with the sheer bulk.
Having tried single transistor I/V and loved it, I found there was still some improvement to be gained by biassing the common-base transistor with additional current sources to reduce its input impedance. Since getting down to the region of 1ohm would require some 25mA of bias which isn't well suited to portable applications I decided to have a go at using feedback to obtain the impedance I'm seeking.
I'm not using an off-the-peg CFB amp because they still turn out to be fairly power supply quality susceptible (subjectively speaking) so here's a design I hope that greatly reduces the supply impedance requirements so that it can be used in a portable player.
The picture shows the second prototype I/V stage, coupled to a 6th order Chebyshev anti-imaging...
ID:	1724   Click image for larger version
abraxalito's Avatar
Views 1493 Comments 2 abraxalito is offline
Old
Designing high order active filters
Posted 20th September 2015 at 11:54 PM by abraxalito
Updated 25th September 2015 at 01:20 AM by abraxalito
I've been getting a lot of use out of Simon Bramble's webpage for designing active filters recently - http://www.simonbramble.co.uk/techar...ter_design.htm. Its a great resource.
Right down at the bottom of the page the last filter he shows the schematic of is a 9th order Chebyshev, 1dB ripple, with a corner frequency of 1kHz. A textbook frequency response plot is obtained using LTC6241s. I latched on to this and tried changing the corner frequency to 18kHz, wondering if I could use such a design for an anti-imaging filter for my DACs. So I divided all the capacitor values by 18 and ran the sim. Disaster! The frequency response I obtained is below - a 7dB spike at 17kHz.
The problem seems to be inadequate Q - high order filters are composed of sections which increase in Q (more positive feedback) and the chosen opamps aren't fast enough (18MHz GBW). I went to a faster opamp for the highest Q stage which brought about some improvement...
ID:	1719   Click image for larger version
ID:	1721   Click image for larger version
ID:	1722   Click image for larger version
abraxalito's Avatar
Views 1045 Comments 7 abraxalito is offline
Old
New tested JLH 2005 class A amplifier, works excellent
Posted 15th September 2015 at 08:12 AM by siliconray
Hi, our engineers just tested JHL 2005 class A amplifier. It works excellent.
The Q1 and Q2 is 2N3055. Also you can choose 2SC3280,MJ15003 or MJ15024. any of them is ok for us.
Posted in Uncategorized
Views 952 Comments 0 siliconray is offline
Old
Taobao headphone amp is an FX box
Posted 14th September 2015 at 01:19 PM by abraxalito
I bought this amp because the case attracted me - no pics on the Taobao page were giving away anything about the insides, quite unusual. After receiving it I couldn't resist having a quick listen and it turns out its a hardwired tone control with bass and treble turned up to the max, about +16dB wrt 1.3kHz. What a surprise! - no matter as I was going to strip out the innards anyway to use as a test platform for my amp.
abraxalito's Avatar
Views 618 Comments 0 abraxalito is offline
Old
Can you identify this opamp from its simplified schematic and PSRR plot?
Posted 10th September 2015 at 01:28 AM by abraxalito
Updated 21st September 2015 at 12:23 AM by abraxalito
In my search for opamps with better real-world PSRR behaviour, I came across this beauty. For now I'll just post up its simplified schematic and PSRR plot - if any of you know of it please put your deduction in the comments. I may add more clues later if nobody nails it early on.
The reason I find this part interesting is its cascoded output stage - I believe this is what leads to the 'hump' in the positive rail PSRR. I've never seen that behaviour on any other device.
Well over a hundred views now and not one single stab at the answer. Its the industrial-strength version of the now obsolete LM308, a Bob Widlar special with super-beta input stage. The output stage cascode I take it isn't primarily to improve the PSRR rather its due to the high maximum operating voltage (72V). TI does still have the DS on its website though it doesn't put in an appearance in parametric search as its been obsolete for a while. Even more interesting is its decompensated variant which...
ID:	1713   Click image for larger version
abraxalito's Avatar
Views 893 Comments 1 abraxalito is offline
Old
Getting CS5381 Distortion down!
Posted 7th September 2015 at 11:35 AM by googlyone
On thinking over the sensitivity of the CS5381 to the drive and input filtering capacitor I decided to explore the capacitors further.
I was also interested to note that a number of manufacturers seem to recommend a range of different capacitor values here.
Purely because it was handy - i.e. right in front of me on the desk - I threw an extra 2nF capacitor across the differential input of the CS5381. Boom - the distortion dropped 6dB straight off.
I muttered a few choice profanities, which made me feel an awful lot better, then arbitrarily threw a 470pf NPO ceramic cap across that lot, just to be sure. Well given I was off doing such arbitrary things - why not?
On analysis, 5nF capacitance at 20kHz is about 1.5K Ohms (reactive) which is within the capability of the op amp to drive.
The results?
Name:	Improved Distortion vs Freq Extra Cap on ADC.jpg
Which I found rather pleasing, as using the "default" 2n7,...
Views 952 Comments 0 googlyone is offline
Old
"Nazar`s regulator", variants
Posted 6th September 2015 at 07:59 PM by Nazar_lv (Creative High end audio)
A couple of variants of this ideal regulator for audio applications.
Ideal because:
1. Stable and small output impedance in the 20-20k area and above (for 2x trans. version ~ 0.05ohm and ~0.005ohm for 3x trans. version).
2. Load current flows locally through the regulator`s output transistor only.
3. Excellent step response.
4. Little capacity electrolytic cap on regulator output or no electrolytic capacitor at all.
Also
5. High PSRR (for 2x trans. version 100db and 120db for 3x trans. version).
6. Noise < 1u (20-20000hz).
7. Simple and reliable.
In addition to the classical 2x transistor "nazar`s regulator" also described 3x transistor version characterized by much better output impedance and PSRR.
Also described a filter/voltage follower that makes better use of supply voltage (Uout...
Nazar_lv's Avatar
Views 1076 Comments 0 Nazar_lv is offline
Old
DIY Audio Analyser using CS4398 / CS5381 - The Limits of These IC's
Posted 6th September 2015 at 11:47 AM by googlyone
Updated 6th September 2015 at 11:56 AM by googlyone
I have had the time to play with the MiniDSP Streamer and my ADC and DACs now.
Initial results were disappointing - and led to me looking very closely at the ADC drive, and particularly the single ended to differential part of the circuit.
Given I pinched this circuit from an application note (and embarrassingly did not question it adequately) gives me little solace that I built, and used this!
Interestingly, Creative Labs did exactly the same thing on the sound blaster that I had so much trouble improving - the single ended conversion is just wrong. This solves the "Puzzle" that I noted in a blog a few months ago - now I know why I just couldn't get better performance out of that CS5381 drop in to the Sound blaster box.
In the process of improving the ADC drive, and to allow experimentation with the input op amps, I built two versions of the ADC drive, one using non inverting buffers and a second that uses inverting...
Name:	ADC_CS5381_Improved_V2_Both Channels In.jpg
ID:	1702   Click image for larger version
Name:	ADC_CS5381_Improved_V2_One Channel Shorted.jpg
ID:	1703   Click image for larger version
ID:	1704   Click image for larger version
ID:	1705   Click image for larger version
ID:	1707   Click image for larger version
Views 1576 Comments 0 googlyone is offline
Old
DIY Audio Analyser using CS4398 / CS5381 (CS5361)
Posted 31st August 2015 at 12:50 PM by googlyone
I recently set to work the guts of the audio analyser:
- MiniDSP USB Streamer
- Interface card
- ADC
- DAC
The ADC and DAC were from an old project. the tests I had been able to do on these were done using simple test gear, I knew the distortion was fairly low - but had been unable to really bottom out the level.
I did know the DAC was down in the 0.001-3% level or below.
Imagine my chargin when I fired the system up, got all the bits running and measured something closer to 0.01% distortion at -1dBc!
I was initially convinced that there was something wrong. After cranking the level down to -10dB, the distortion dropped to 0.001%. Further tesing (I ran the DAC at -1dBc and attenuated the output) proved that it was the ADC dominating the measurements.
Much fiddling led to me concluding that the ADC buffers were the culprit. I would like to blame...
ID:	1697   Click image for larger version
Views 1926 Comments 2 googlyone is offline
Copyright 1999-2017 diyAudio
