Go Back   Home > Forums > Blogs
Old
Ground loop noise, why it is and what you might do about it
Posted 19th January 2016 at 12:37 AM by bwaslo
I recently was motivated to figure out numerically what might be happening when you get hum out of your power amplifier only when connecting other cables to it. And why a fix I sometimes use works so well.
Before you go blowing your budget on expensive audio isolation transformers, please take a look!
http://libinst.com/GroundNoise/The%2...se%20issue.pdf
Hope someone finds this useful.
Bill
bwaslo's Avatar
Posted in Uncategorized
Views 1079 Comments 2 bwaslo is offline
Old
45watts Class B
Posted 15th January 2016 at 08:11 AM by naxilla100
can anyone verify this circuit
someone says the power transistors are swapped,
but it seems ok to me .....
has anyone built this circuit before .....
naxilla100's Avatar
Views 600 Comments 1 naxilla100 is offline
Old
Highly affordable digital audio CPU board
Posted 8th January 2016 at 04:02 AM by abraxalito
STM's lowest cost ARM Cortex M4 CPU is now available on a very low cost evaluation board here - https://item.taobao.com/item.htm?spm...cket=13#detail
Its quite a good fit for audio purposes because there are a couple of I2S interfaces with a dedicated audio PLL. There's plenty of RAM (64k) and according to the benchmarks, it'll do the equivalent of around 100MIPs. Its also respectably low power when running out of RAM - use the flash memory accelerator though and its not quite so frugal.
Click image for larger version
abraxalito's Avatar
Views 702 Comments 0 abraxalito is offline
Old
Description of digital distortion meter design, with CAD files
Posted 5th January 2016 at 11:48 AM by googlyone
Updated 10th January 2016 at 06:45 AM by googlyone (Update documents)
I have been asked for the CAD files for the distortion meter I recently built.
NOTE 10 Jan 2016 : I have changed the clock driving and distribution PCB as it really needed to be more versatile to me to run a mix of CS and AKM ADC and DACs. The change allows selection of MCLK at different multiples on the ADC and DAC via jumpers on the board. Again this is prpobably a bit more "hard wired" than a generic consumer device would be, but allows stable operation for fixed sample rate systems.
WARNING:
This project is not a super straight forward "chuck it together and it will all be fine" sort of build. I am providing what is essentially a collection of USB interface (MiniDSP), power supply (mine - open source), backplane, clocking and galvanic isolation (mine - open source), A/D and D/A (mine - open source) and a differential interface and attenuator (Silicon Chip magazine), though I am strongly tempted to do my own.
Views 846 Comments 1 googlyone is offline
Old
Repairs to Fender PD250 Complete
Posted 3rd January 2016 at 02:36 AM by tscr2015
While after about 6 months of working on my Fender PD-250 PA System, I finally got it back together tonight and it works great. I don't think that I am going to mess with it any more.
Thanks to everyone on the forums for the help and suggestions. This should be ready to rock the parade season this coming year. Right now I can vibrate the floors of my office/work area with about quarter volume.
Stay tuned to this as I work on the Hiphonics zxi1008 amp that I have on the bench now.
Till then Have a good one
Tom
Views 295 Comments 0 tscr2015 is offline
Old
F6 Adventures
Posted 18th December 2015 at 04:36 AM by 2 picoDumbs
Updated 4th February 2016 at 11:58 PM by 2 picoDumbs
Contained here are all my observations with this amp.
1) The schematic the DIYAUDIO Store PCB is based on does not allow 2nd harmonic adjustment through changing source resistor values.
2) The PCB circuit can be changed to the original degenerating circuit by moving cap leads to other side of resistor lead. This will restore 2nd harmonic adjustment through source resistance modification.
3) Output impedance also appears to be significantly affected (only tested in simulation).
4) As an alternative to the PCB mod, 2nd Harmonic adjustment can be altered on PCB circuit by selecting devices with different transconductance curves if one does not want to modify the PCB.
5) As an alternative to performing transconductance measurements and selecting non-matched devices for 2nd harmonic addition, installing one IRFP250 and one IRFP240 per channel will also give a dominant 2nd harmonic.
Continue reading
2 picoDumbs's Avatar
Views 1440 Comments 0 2 picoDumbs is offline
Old
DIY Audio Analyser using CS4398 / CS5381 - UPDATE!
Posted 15th November 2015 at 09:05 AM by googlyone
I have more or less completed the audio analyser based on CS4398 and CS5381.
In an earlier post I suggested I had reached the limits of these IC's. I was wrong. What I had reached the limit of was getting the grounding "OK" for a single (unbalanced) input measurement system.
I have since built a balanced front end - in fact I simply built a Silicon Chip PCB as it was pretty well what I would do - and integrated this to the ADC and DAC.
It looks a bit like this:
What you see is:
- On the left are two independent power supplies
- In the back middle is a MiniDSP USB Streamer card.
- In the middle back is an interface card that
- Does optical isolation of the MiniDsp USB Streamer
- Does more regulation for the ADC and DACs
- Generates local clocks for the DAC and ADC
- Feeds these back to the MiniDSP Streamer
Name:	1kHz -6dB 192ks.jpg
ID:	1757   Click image for larger version
Name:	1kHz -4dB 192ks.jpg
ID:	1758   Click image for larger version
Name:	1kHz -1dB 192ks.jpg
ID:	1759   Click image for larger version
Name:	10kHz -4dB 192ks.jpg
ID:	1760   Click image for larger version
Name:	DAC_Off 192ks.jpg
Name:	DAC_Off 40dB Att192ks.jpg
ID:	1762   Click image for larger version
Name:	2015_11_14 48ks-s -6dbc.png
Views 1415 Comments 4 googlyone is offline
Old
B-board v2 line driver : development circuit
Posted 30th October 2015 at 12:49 PM by rjm (RJM Audio Blog)
Updated 30th October 2015 at 12:56 PM by rjm
Original version is here.
I've been meaning to get around to updating this by folding in the improvements to the diamond buffer stage made during development of the Sapphire 3 headphone amplifier. Here is the first look of the bboard v2 under LTSpice.
I've gone back to simple emitter resistors on the input, running under much lower current to keep the input impedance high. The output is simplified to a basic Sziklai compound transistor pair with the bulk of the bias current running in the second transistor.
In terms of distortion, for line level output level, CCS loaded input has no advantage. I'll have to double-check PSRR and a few other things before signing off on this version though.
FYI only, not a production circuit.
rjm's Avatar
rjm
Views 1051 Comments 7 rjm is offline
Old
Nelson Pass Presentation
Posted 26th October 2015 at 04:50 PM by Michael Rothacher (Audiohobby.com)
Updated 26th October 2015 at 04:53 PM by Michael Rothacher
Here's the link to Nelson's presentation at BAF 2015:
Pass Presentation BAF 2015
Slides are available in pdf. See the video description for the link.
Michael Rothacher's Avatar
Views 715 Comments 0 Michael Rothacher is offline
Old
Speaker Building
Posted 23rd October 2015 at 03:10 AM by 2 picoDumbs
Testing compression driver
https://youtu.be/KMe5_nNoAD0
Views 644 Comments 0 2 picoDumbs is offline
Copyright 1999-2017 diyAudio
