Go Back   Home > Forums > Blogs > dvb projekt
Reference TDA1541A DAC
Old
Digital input section completed!
Posted 12th August 2013 at 06:56 AM by dvb projekt
Updated 3rd December 2015 at 04:32 PM by dvb projekt
Now the digital input section is completed!
Wave I/O for USB input --> SPDIF/AES input board --> FIFO --> Isolator board -->
Dual Clock board with Crystek CCHD-957 clocks (powerd exclusive from a A123 Systems LiFePo4 cell) -->
Ians I2S to PCM V2.0 Module --> Red Baron
Because i use two Red Barons parallel, i added two additional U-FL connectors for DR and DL.
dvb projekt's Avatar
Views 1978 Comments 2 dvb projekt is offline
Old
Tube-I-zator Output Cap Upgrade
Posted 3rd May 2013 at 03:23 PM by dvb projekt
Updated 30th November 2016 at 08:58 AM by dvb projekt (Sound review added)
My last dream come true!
The output cap upgrade to the holy grail...
DUELUNDs CAST PIO Copper Cap!
Therefore the Tube-I-zator must go to the 2nd floor
Sound review
Now after ~150 hrs. burn in time, i will share my impressions with these outstanding caps.
I had a dj vu after changing from my previous Mundorf Suprem silver/gold/oil caps to the Duelund CAST PIO Copper.
The same difference as in my 300B mono blocks.
This openness, clarity, three-dimensionality with so many more subtleties and micro informations, absolute breathtaking.
Only the Duelund CAST has
Views 1848 Comments 3 dvb projekt is offline
Old
Secure source for A123 Systems LiFePo4 cells
Posted 16th April 2013 at 04:53 PM by dvb projekt
Updated 30th November 2016 at 09:08 AM by dvb projekt (2nd source added)
All members who want to use LiFePo4 cells from the leading company A123 Systems
and want a secure source to get no fakes,
could order them at Lipopower Ltd. in Germany.
The original cells are from the German A123 Systems distributors Reva or BMZ.
You could order them with or without solder taps.
Click the image to open in full size.Click the image to open in full size.
Also a Ri selection is possible.
International shipping and paypal payment is no problem!
P.S.: If you have any questions, send an e-mail to Mr. Karl-Heinz Hofmann with regards from me!
Ive got an email from A123 Systems with a 2nd source
Views 2245 Comments 0 dvb projekt is offline
Old
Red Baron V4.0 - 3.3V I2S attenuator modification
Posted 29th March 2013 at 01:15 PM by dvb projekt
Updated 30th November 2016 at 09:10 AM by dvb projekt
Views 1874 Comments 0 dvb projekt is offline
Old
Red Baron V4.0 free running DEM oscillator modification
Posted 29th March 2013 at 12:02 PM by dvb projekt
Updated 30th November 2016 at 09:11 AM by dvb projekt
Views 1569 Comments 0 dvb projekt is offline
Old
Personal announcement
Posted 26th March 2013 at 05:24 PM by dvb projekt
Updated 26th March 2013 at 05:27 PM by dvb projekt
Well my friends it is time again to say thanks to all of you, who like and ordered my pcbs.
Because i am no developer of electronic circuits but have the knowledge to design pcbs,
i wanted to give something back to the community.
Since i started with my 1st pcb, the Optical-Volume-Control on 15th October 2009,
a small donation from every sold pcb goes to diyaudio.com
Today i am proud to say that your cumulated donation achieve
$ 3104
Keep on having fun with my pcbs and best regards
Oliver
Views 1094 Comments 4 dvb projekt is offline
Old
Rating: 2 votes, 5.00 average.
Tube-I-zator / TDA1541A recommended modification #2
Posted 24th March 2013 at 02:10 PM by dvb projekt
Updated 30th November 2016 at 09:13 AM by dvb projekt
Views 1563 Comments 1 dvb projekt is offline
Old
Tube-I-zator V2.0 / TDA1541A recommended modification
Posted 20th March 2013 at 10:11 PM by dvb projekt
Updated 30th November 2016 at 09:14 AM by dvb projekt (Resistor type added)
Views 916 Comments 0 dvb projekt is offline
Old
The best sounding I/V resistor
Posted 3rd March 2013 at 10:22 AM by dvb projekt
Updated 30th November 2016 at 09:17 AM by dvb projekt
As many of you know, i am using the Texas Components TX2575 Bulk Z-Foil resistor for a long time
in important circuit positions, especially as I/V resistor.
Recently i stumbled over a short recommendation from Thorsten Loesch.
Originally Posted by ThorstenL View Post
I would second Rohpoint, Neohm less. Rohpoint are truely excellent. For my first TDA1541 Non-OS DAC (in 98) I handmade bifilar wound Non-inductive 25 Ohm resistors.
In susequent builds I compared to Rohpoint (which I have used extensively and found no reason to handwind resistors.
In my commercial designs we use a specfic type of SMD resistors after auditioning tons.
Some SMD resistors are really bad, some are so-so and some are most excellent, though no patch for a Rohpoint Squaristor GR102.
Ciao T
Because i know Thorsten as a man who had the perfect sound in mind,
i ordered one pair 30R to try them in my Tube-I-zator.
Views 8167 Comments 16 dvb projekt is offline
Old
NOS TDA1541A double crown
Posted 27th January 2012 at 05:54 PM by dvb projekt
Updated 30th November 2016 at 09:23 AM by dvb projekt
I am a lucky man!
Ive got two NOS TDA1541A double crown DACs from a friend
He bought the last from Philips a long time ago...
Just now i swapped them on my Red Baron modules...
What could i say.... They will never leaving the DAC modules again !!!
Views 4046 Comments 5 dvb projekt is offline
Copyright 1999-2017 diyAudio
