+/- Power Supply Module
- up to 15 caps per rail (16mm to 18mm diameter)
- place for decoupling foil cap in each rail
- place for bleeder resistor
- 105µm copper weight
- 2mm pcb
- Immersion Gold
- green soldermask on both side
- Board size 195mm x 120mm
Sold out
Shunt regulator modules
circuit design by Salas
- Shunt regulator module for TDA1541A (+5V, -5V, -15V)
- separate Shunt regulator module for additional parts (+5V)
- 70µm copper weight
- 2mm pcb
- Immersion Gold
- Board size 147mm x 115mm (46mm x 115mm; single +5V)
TDA1541A shunt module 2pcs. left in stock
