Go Back   Home > Forums > Blogs
Old
Red Baron V4.0 - 3.3V I2S attenuator modification
Posted 29th March 2013 at 01:15 PM by dvb projekt
Updated 30th November 2016 at 09:10 AM by dvb projekt
dvb projekt's Avatar
Views 1874 Comments 0 dvb projekt is offline
Old
Red Baron V4.0 free running DEM oscillator modification
Posted 29th March 2013 at 12:02 PM by dvb projekt
Updated 30th November 2016 at 09:11 AM by dvb projekt
Views 1569 Comments 0 dvb projekt is offline
Old
Personal announcement
Posted 26th March 2013 at 05:24 PM by dvb projekt
Updated 26th March 2013 at 05:27 PM by dvb projekt
Well my friends it is time again to say thanks to all of you, who like and ordered my pcbs.
Because i am no developer of electronic circuits but have the knowledge to design pcbs,
i wanted to give something back to the community.
Since i started with my 1st pcb, the Optical-Volume-Control on 15th October 2009,
a small donation from every sold pcb goes to diyaudio.com
Today i am proud to say that your cumulated donation achieve
$ 3104
Keep on having fun with my pcbs and best regards
Oliver
Views 1094 Comments 4 dvb projekt is offline
Old
Rating: 2 votes, 5.00 average.
Tube-I-zator / TDA1541A recommended modification #2
Posted 24th March 2013 at 02:10 PM by dvb projekt
Updated 30th November 2016 at 09:13 AM by dvb projekt
Views 1563 Comments 1 dvb projekt is offline
Old
Tube-I-zator V2.0 / TDA1541A recommended modification
Posted 20th March 2013 at 10:11 PM by dvb projekt
Updated 30th November 2016 at 09:14 AM by dvb projekt (Resistor type added)
Views 916 Comments 0 dvb projekt is offline
Old
The best sounding I/V resistor
Posted 3rd March 2013 at 10:22 AM by dvb projekt
Updated 30th November 2016 at 09:17 AM by dvb projekt
As many of you know, i am using the Texas Components TX2575 Bulk Z-Foil resistor for a long time
in important circuit positions, especially as I/V resistor.
Recently i stumbled over a short recommendation from Thorsten Loesch.
Originally Posted by ThorstenL View Post
I would second Rohpoint, Neohm less. Rohpoint are truely excellent. For my first TDA1541 Non-OS DAC (in 98) I handmade bifilar wound Non-inductive 25 Ohm resistors.
In susequent builds I compared to Rohpoint (which I have used extensively and found no reason to handwind resistors.
In my commercial designs we use a specfic type of SMD resistors after auditioning tons.
Some SMD resistors are really bad, some are so-so and some are most excellent, though no patch for a Rohpoint Squaristor GR102.
Ciao T
Because i know Thorsten as a man who had the perfect sound in mind,
i ordered one pair 30R to try them in my Tube-I-zator.
Views 8167 Comments 16 dvb projekt is offline
Old
The Red Baron DAC Module V4.0 - Out of production
Posted 8th February 2013 at 09:34 AM by dvb projekt
Updated 30th November 2016 at 10:21 AM by dvb projekt
The Red Baron
V4.0
The evolution brings the following changes
- Separate I2S-GND route to Digital-GND
- Separate Analog Output GND route
- Separate GND route for active divider decoupling caps to Analog-GND
- Modified active divider decoupling pads for better SMD 1210 caps soldering
- Onboard SOT353 footprint for fastest DEM-Synchronizer ICs
- Un-interrupted ground plane
- MOSFET Source/Drain failure corrected
Still on the module
- Direct shunt voltage inputs with shortest onboard traces
- I2S In-/Outputs with shortest onboard traces
- I2S Attenuator and DEM Synchronizer
(by -ecdesigns-)
- Onboard Grounded-Gate MOSFET Current Buffer I/V Stage
(-ecdesigns- MK7 version)
- Separate GND-Trace for DEM-Synchroinizer
- Master/Slave
File Type: zip TDA1541A Project - BOM - for The Red Baron V4.zip (9.3 KB, 809 views)
Views 3119 Comments 0 dvb projekt is offline
Old
Ceasar II 300B SE mono block upgrade Part #2
Posted 24th July 2012 at 06:01 PM by dvb projekt
Updated 13th November 2015 at 10:41 AM by dvb projekt (New photo source)
A short quick upgrade for my Ceasar II Monos
to push the sq to the limit...
In the meantime...
As you could see in the Upgrade Part #1, the printing of the Sophia Electric Royal Princess 300B
is 90 degrees different to the Emission Labs 300B-XLS.
Not a big thing, but its not looking good!
Unfortunately i have only two holes for the Tube-Socket. Therefore i made two small adapter to rotate the Tube-Socket.
Now the printing faces to the front!
Perfect!
Views 2371 Comments 0 dvb projekt is offline
Old
Ceasar II 300B SE mono block upgrade Part #1
Posted 5th July 2012 at 06:36 PM by dvb projekt
Updated 16th May 2016 at 02:07 AM by dvb projekt (New photo source)
The last upgrade i made is to swap from the very good sounding Emission Labs 300B-XLS to
For me the best sounding 300B on the market!
The parts for further upgrading are:
The caps C2 & C3
1st Upgrade
The Mundorf silver/gold/oil are changed to the new Duelund Cast PIO-Cu.
Views 2559 Comments 0 dvb projekt is offline
Old
Ultra high-end amplifier for Stax Electrostatic Headphones
Posted 9th June 2012 at 09:23 AM by dvb projekt
Because my Stax SR-404 Limited is now one year in his box without using...
...i start a new project, based on the fabulous circuit from Andreas Rauenbuehler on high-amp.de
The Transistoramp V4.0
My pcbs are ready and now i am collecting the parts.
A set of wonderful teflon Stax Pro and Normal jacks, ive got from a group buy on Head Case.
Click the image to open in full size. Click the image to open in full size.
So stay tuned...
Posted in Project builds
Views 4114 Comments 1 dvb projekt is offline
Copyright 1999-2017 diyAudio
