Go Back   Home > Forums > Blogs > dvb projekt
Rate this Entry
The Red Baron DAC Module V4.0 - Out of production
Posted 8th February 2013 at 09:34 AM by dvb projekt
Updated 30th November 2016 at 10:21 AM by dvb projekt
The Red Baron
V4.0
Click the image to open in full size.
The evolution brings the following changes
- Separate I2S-GND route to Digital-GND
- Separate Analog Output GND route
- Separate GND route for active divider decoupling caps to Analog-GND
- Modified active divider decoupling pads for better SMD 1210 caps soldering
- Onboard SOT353 footprint for fastest DEM-Synchronizer ICs
- Un-interrupted ground plane
- MOSFET Source/Drain failure corrected
Still on the module
- Direct shunt voltage inputs with shortest onboard traces
- I2S In-/Outputs with shortest onboard traces
- I2S Attenuator and DEM Synchronizer
(by -ecdesigns-)
- Onboard Grounded-Gate MOSFET Current Buffer I/V Stage
(-ecdesigns- MK7 version)
- Separate GND-Trace for DEM-Synchroinizer
- Master/Slave connectors for parallel DAC module usage
and external I/V Buffer stages e.g.
Tube-I-zator & DDNF Stage
- no SMD Design
The PCB has the following data:
Material: FR4 - 2mm
Layers: 2
Board size: 125x73 mm
Surface finish: Immersion Gold
Copper weight: 35m
Soldermask: Both sides - red
Silkscreen: Legend on top
Out of production
File Type: zip TDA1541A Project - BOM - for The Red Baron V4.zip (9.3 KB, 809 views)
Views 3119 Comments 0
New To Site? Need Help?
Copyright 1999-2017 diyAudio
