Go Back   Home > Forums > Blogs > dvb projekt
Rate this Entry
The final parts for the Reference DAC Case
Posted 25th April 2011 at 10:26 AM by dvb projekt
Updated 30th November 2016 at 09:54 AM by dvb projekt
On the left side
USB-Isolator from Circuits@Home
Teralink X2 USB to I2S converter (with my modification)
TDA1541A Salas shunt reg. module
+5V Salas shunt reg. module
(downlink side of USB isolator incl. +5V line of Teralink X2/ Twisted Pear WM8804 / Ultra highspeed buffer module / I2S switch)
+3,3V Salas shunt reg. module (+3,3V line of Terlink X2)
In the middle
Twisted Pear WM8804 SPDIF to I2S converter
On top the Ultra High Speed Buffer module
I2S switch
2* TDA1541A DAC module with direct input shunt mod.
On the right side
2* SSHV-Shunt module (one for each channel)
Tube-I-zator V2.0
(the remaining parts of the onboard HV-PSU are not necessary,
because of the Tube-Rectifier in my separate PSU case)
Total Comments 0
Comments
Copyright 1999-2017 diyAudio
