Go Back   Home > Forums > Blogs > Wayne737
Rate this Entry
Guitar tone pot and caps
Posted 1st May 2010 at 01:52 PM by Wayne737
I have a quetion about guitar tone potentiometers and capacitors. A build I'm working on has a preamp. Must the tone control be before the preamp? And all the tone control is at the first part of the potentiometer. I want it to adjust the tone across the entire potentiometer. Would that have to do the the potentiometer, capacitor, or how it is wired?
Posted in Uncategorized
Views 1511 Comments 1
Total Comments 1
Comments
  1. Old Comment
    keep the tone control before the preamp, passive tone controls are high impedance, the out put of the preamp will be low impedance. To get a wider range of control you need a pot with a different taper, if the one you have is log, try a linear taper pot and vice versa.
    more on pot tapers here: Potentiometers (Beginners' Guide to Pots)
    permalink
    Posted 6th May 2010 at 06:15 AM by PeteMcK PeteMcK is offline
Copyright 1999-2017 diyAudio
