Go Back   Home > Forums > Blogs > abraxalito
Rate this Entry
SAA7220 filter replacement project
Posted 20th September 2016 at 12:24 PM by abraxalito
Some years ago I reverse engineered the coefficients of the Philips SAA7220 filter, just for fun. At that time the microcontroller I implemented the filter on (LPC1114) didn't have a fully implemented I2S interface so I needed additional logic to get the data in (an array of 74HC595s) and I used the SSP to output a serial stream, albeit not reliably as I didn't implement a foolproof method of generating WS. Hence the filter wasn't ready for primetime.
Now though STM has introduced a Cortex M0 MCU which does have the dedicated I2S ports to realize a pukka emulation of the SAA7220. At least that's what I'm hoping - I know the code worked on the LPC1114 but I seem to recall I needed a slight overclock - there is a report that the STM32F072 can be overclocked but I shall need to check this out for myself. One major advantage this replacement will have is going to be lower power consumption - something of the order of 100mW or under.
In order to kick this project off, I've ordered off Taobao some of these boards (35rmb a piece). Stay tuned for updates all you TDA1541A lovers
Save
Click image for larger version
Total Comments 8
Comments
  1. Old Comment
    triode_al's Avatar
    Interesting!
    Once you do this bottom up, why not interface directly on the front end to a S/PDIF flow, without a receiver chip??
    permalink
    Posted 13th November 2016 at 07:40 PM by triode_al triode_al is offline
  2. Old Comment
    abraxalito's Avatar
    Sorry, you lost me here! S/PDIF out is being generated by the SAA7220 that's the chip we're replacing....
    permalink
    Posted 14th November 2016 at 01:11 AM by abraxalito abraxalito is offline
  3. Old Comment
    triode_al's Avatar
    Sorry, I forgot my thinking!
    Still I am interested what comes out & how this can be shared.
    permalink
    Posted 19th February 2017 at 03:50 PM by triode_al triode_al is offline
  4. Old Comment
    abraxalito's Avatar
    Glad you're interested, I've been working on other things as there seems to be so little interest.
    permalink
    Posted 20th February 2017 at 12:04 AM by abraxalito abraxalito is offline
  5. Old Comment
    I'm interested and I think a lot of TDA1541A chip lovers will also be interested if it will improve the sound.
    No problems if it takes time and you have other things to do.
    permalink
    Posted 7th April 2017 at 03:19 AM by ekidnah09 ekidnah09 is offline
  6. Old Comment
    abraxalito's Avatar
    I'm fairly sure (although I've not listened to a TDA1541A) that NOS sounds best but probably the reduction in power supply noise will give some SQ advantage to 4X OS with the ARM CPU.
    permalink
    Posted 9th April 2017 at 10:03 AM by abraxalito abraxalito is offline
  7. Old Comment
    giro1991's Avatar
    Any progress?
    permalink
    Posted 19th May 2017 at 03:02 PM by giro1991 giro1991 is offline
  8. Old Comment
    abraxalito's Avatar
    No - in the absence of some end-users cheering me on I'll be working on another couple of projects (a DAC and an amp). Once I get back into microcontrollers and programming them this project is likely to go ahead even in the absence of strong demand though. Can't say when that'll be though...
    permalink
    Posted 19th May 2017 at 11:21 PM by abraxalito abraxalito is offline
Copyright 1999-2017 diyAudio
