Sony VFET version 2 AL Boards Build Blog
In the rare case you happen upon matched pairs of these transistors, and you like drilling, and you think my boards may be Ok, then go ahead and read this blog.
As a starting point, we settled on this schematic for the working amplifier. Some modifications were done from the original, and Botte made some changes to get a slower turn on rate for the boards.
Note, R37,R38 and C1 and C2 have been changed. However, feel free to use original values.
Also note, for greater viability of use of JFETs beyond 8ma IDSS, source resistors can be used here ( I used 10R with 9ma pairs) - Otherwise jumper this location.
Q13 and Q14 are BC550c and BC560c. Originally Toshiba bipolars were used on my boards, but they were not stable in voltage and gain suffered on the boards. The boards have since had the pads altered to remove them. The BC bipolars work like a charm.
We started building this amplifier (Botte, Flochhini and myself) with the Front end boards in mind. The intent of the boards was to allow for use as a pre-amplifier standalone, although I have not personally tested it's use for that.
Building this alone, it is possible to get the offset fairly good, assuming you have matched KJFETs.
Here is the front end (both sides, shorts by Gbethe). Board layout by CRT and myself
Board size is 36mm x 175mm
Here is the Output Stage - board size is 54mm x 285mm
So, here is a schematic to show what is really missing here, and what is added.
Current measurements should be taken across a power supply with DMM on each rail assuming a resistance in PS .1R, then it will work like the Article description.
Here is the Output stage pre drilling. I used a small and large sharpie to outline the holes, and then generally made holes 140% the size they needed to be in the end, to allow for some room for errors in drilling, and to avoid shorts if the teflon covering of the FETs did not work.
Botte version.
Here is the built up version showing the connectors, the Aluminum Angle mounting piece.
From Botte's fine work. Note how practical he is with his money, using the TO-247 IRFP's instead.
Recommended
BOM Parts
Here is an important piece. The boards are ideally connected via the following 2x10x2.54 headers and pins.
PN are
4 - PPPC102LJBN-RC - Digikey - S5563-ND
4 - PBC10DBAN - Digikey PN- S2111E-10-ND
4- Front end Heatsinks - 637-10ABPE or similar
TL431ACLPR - Buy extra, if something will short, it will likely be these that die. The TL431B were found not to work well. Use "A" type.
For C1,C2, and C7,C8 winder spacing has been made for 50v Elna Silimic Caps. C1 and C2 are of larger value in this circuit. 50V as Botte deemed there might be more than 35v hitting them. I used 50v Panasonic FM throughout, and bypassed with small wima caps.
You should do your best to protect from shorts.
I put teflon around all the bolts, put them on pins to if you have the correct diameter teflon.
Here is a few short videos of a working channel
https://youtu.be/kWSlbYg01pQ
https://youtu.be/4KhfLfaWXq0
GB Thread for board, if you've made it this far.
Botte version.
Recommended
BOM Parts
PN are
Total Comments 3
Comments
Any boards for sale?
Posted 19th April 2017 at 06:03 AM by jlithen -
I'm interested in a set of boards if/when available. Please LMK.
Posted 19th April 2017 at 01:47 PM by Berd -
Would be interested in a set of these boards if available. THanks.
Posted 21st April 2017 at 04:09 AM by YCLee
