Go Back   Home > Forums > Blogs > panson_hk
Rate this Entry
LME49810 300 W amp kit from TaoBao (Mods)
Posted 23rd September 2011 at 07:19 AM by panson_hk
The THD performance of this board can be improved by separate the input/NFB ground from the decoupling grounds. This is a common mistake in many kits.
Simply cut the trace as shown in the figure and connect the input/NFB ground to supply ground via a separate wire. THD improves as shown in the figure.
Click image for larger version
ID:	489   Click image for larger version
Name:	THD vs power 1k 20k 20Hz 8Ohm 23 Sep 2011.jpg
ID:	490   Click image for larger version
Name:	THD vs power 1k 20k 20Hz 8Ohm Ground isolated.jpg
Posted in Uncategorized
Views 4777 Comments 1
Total Comments 1
Comments
  1. Old Comment
    HoneyBadger's Avatar
    Can you comment on the quality of this amp? Also, why did you add the capacitor?
    Apologies for bumping an old thread.
    permalink
    Posted 3rd January 2014 at 07:10 PM by HoneyBadger HoneyBadger is offline
Copyright 1999-2017 diyAudio
