LM3886 x 3 First Test
Posted 16th August 2011 at 05:29 AM by panson_hk
I briefly measured the LM3886 x 3 parallel board this morning. THD vs freq for one, two in parallel and three in parallel are measured.
Load of 4 Ohm was also tested. When using one 3886, the on-chip protection activates periodically when doing low frequency (~ < 500 Hz) test. No such protection operation happens for the same output level for higher frequencies (>1kHz). The problem goes away when using 3886s in parallel.
More systematic tests will follow.
Total Comments 3
Comments
Posted 16th August 2011 at 08:20 AM by abraxalito -
Posted 19th August 2011 at 02:21 AM by panson_hk -
I saw your post with the 80k filter on the 'Parallel 3886' thread - but the plots look too small on my screen. (My eyesight also is not so good ha). Would you be able to post up bigger plots? I'm curious to see the improvements!
<edit> Maybe one idea is to expand the scale so the curves appear further apart - make the max displayed distortion 0.05% perhaps?Posted 20th August 2011 at 12:45 AM by abraxalito
Updated 20th August 2011 at 12:47 AM by abraxalito
